Image size problem
Greetings
I have 150 scanned images (4x6x300dpi) and I want to bring them into Premiere Pro 1.5. When I do they are oversized in the monitor window. Heads chopped off etc. They are fine in the edit window. Is there some way I can set the aspect ration when importing so they will all fit automatically? Thanks |
I would do one image, find the right settings in the Effect Controls tab. Then Click motion on that tab, press Ctrl+C. Then, click on every clip on the timeline, press Ctrl+V, and it will copy the same settings from that first picture onto the rest.
You can go to project properties and under general select the little square that automatically scales images/footage to fit project size.
