re-capturing DV footage from an HDV source?
I have footage shot originaly in HDV. It was captured in premiere in DV and edited in DV. I want to re-capture that footage in HDV now and have the edit stay intact. What is the procedure to re-capture that footage in HDV?
Do I just make each clip "ofline" and then batch re-capture all the shots in HDV mode now? |
Yeah, I want to know the exact same thing? shooting from the FX1...
anyone with experience? admittedly i haven't even tried yet! cheers |
Hmm. You can't just capture within premiere and hope they would link automatically. You could capture them anyway and then offline/link manually. Can get to be tedious. Even if you capture them in a seperate project and copy over the originals, then relaunch PPro, the app might complain and you'd be forced to manually offline/relink/scale.
I would create a dummy project with a clip or two and test this out. |
EDL, Maybe?
You might be able to export your cuts, etc., as an EDL, or as several EDL files, depending on how many video/audio tracks are in your sequences. Then you could import the EDL(s) into an HDV project, and online your HDV via batch capture, or capture and link media.
Just a thought. The most important thing is being able to get your cut points in the new project. But PPro 1.5.x can export sequences as EDL files, so that may be a good way to get that done. Hope this helps a little, Matt |
