Ki Pro 2.0 Firmware Now Available
2.0 firmware introduces the following new features:
8 channel audio support - Choose between 2 channels or 8 channels of audio via embedded SDI Gang recording - Use the web UI and ethernet connections to Ki Pro units on a common network to start and stop recordings Custom Clip Naming - Allows users to define their own naming convention using the front panel UI or the web UI RS-422 support - Allows interaction with some serial control devices and some non-linear editors Note: *AJA has specifically tested with JL Cooper and FutureVideo 9-pin serial controllers. *Other controllers may also be used, but may have not yet been tested by AJA. AJA has specifically tested 9-pin serial control with Apple Final Cut Pro's Log and Capture and Edit to Tape for RS-422 compatibility. *Other non-linear editors, such as Adobe Premiere Pro, Avid Media Composer, Autodesk Smoke and Sony Vegas, do not yet fully support ingest/output control via RS-422 when used with Ki Pro. *Future firmware updates to Ki Pro will continue to add support for additional non-linear editors when controlling Ki Pro via RS-422. Be sure to consult the Ki Pro Manual for detailed information on 2.0 features and configuration guidelines. |
