3.5mm mini to 1/4" stereo cable
I am looking for a STEREO 3.5mm - STEREO 1/4" PHONE cable at least 25' long. I've google it and can't believe that I haven't run across something. If you have one where did you purchase it? I need to buy one pronto.
You might want to indicate the gender of the connectors on each end you are looking for...
In any event, is this what you are looking for?
male to male. didn't think about that when posting originally.
Thanx Charles that's it.
trs to 3.5mm
First I would ask what you intend to use this cable for, as both of these format connectors are rarely used for the same purpose. TRS (1/4" stereo) is usually used as a Balanced version of 1/4" (equivalent to XLR) for line level balanced MONO signals. where 3.5mm (mini stereo) is usually used for "Stereo" unbalanced signals. in the TRS format the cabling inside is usually configured with the ground to shield and pin 2 to tip and pin 3 to ring, in the mini it is usually ground to shield with tip being right and ring being left (utilizing the 3 conductors ) . but these two types of signals are not compatible (Mini is never used for Balanced signals). The main reason you don't usually see this kind of cable over 20 feet long is because more than likely used to send an un-balanced audio signal somewhere, and un-balanced signal is thought to have a maximum "Clean" distance limit of 20 feet (actually 12 if you're more of a purist).
TRS to 3.5mm
Well... if you read I never said they are "never" used in this fashion(except for the 3.5mm). I stated that the use is "rare" as far as why a TRS would be connected to a 3.5mm, especially for that distance .(yes headphone is probably the only time I can think of that this would be used) and if you can show me a piece of gear that uses 3.5mm balanced audio, I will gladly tuck my tail and walk away, (never seen one in the last 18 years in the AV industry), but hey I might be wrong, it does happen. the reason why I was asking as to what the purpose for this cable was, is because sometimes people assume that because its a 3 conductor cable it must all be the same, I have seen too many people connect a Balanced TRS (constantly bein called a stereo 1/4")to the balanced output of a mixer and plug the other side (3.5mm) to a mic or line input of some device like a laptop or camera, only to find themselves with all sorts of phasing problems among others. so my reason for this question is to find out if there perhaps is a better (more proper) way to make the connection he is trying to achieve, depending on his application, there perhaps needed to be wired in a different fashion, or a splitter or combiner needed.
