4-Chan Audio recorder
Is there an audio recorder with four XLR inputs that works for ENG situations? I mean, instead of recording into the camera feeds (which are only 2 with my camera), is there a portable recording devise for 4 mic lines available?
Sound Devices 744T
If you're flush with money, here's what the big boys use: http://www.sounddevices.com/products/744t.htm Happy hunting, Michael |
I might mention, while the 744 Michael referred to records 4 channels, it only has 2 mic level inputs. The other 2 are line level only. The solution for more mics is to add an outboard mixer, even a basic one like the MixPre, to take the other 2 mics and feed them to the recorder's inputs 3 & 4. An even more sophisticated arrangement is to use a SD 442 mixer in front of the 744 recorder. The mics feed to the mixer channels 1 thru 4. On that mixer each channel has a line level direct out that can go to the 4 recorder inputs, while the main stereo mix can be sent to the camera's audio inputs if desired. In fact, that mixer can feed the main stereo mix independently to 3 different cameras at once plus send each input channel to a 4 channel iso recorder as well if you really needed to do something that complicated.
You could also consider the Fostex PD606
http://www.fostexinternational.com/d...ts/pd606.shtml |
http://www.bhphotovideo.com/c/produc...e_DVD_RAM.html This looks like the best option for your needs. Portabrace makes a nice case for it, so you can get two and sling one over each shoulder, keeping you in balance. |
I believe the new-soon-to-be-released Edirol R44 is going to be a hot ticket for videographers who, maybe on a smaller budget, but yet want the flexibility of a small/battery powered 4 channel recorder. The R44 incorporates many of the features of its big brother (the R4 Pro) at a very affordable price.... A simple sync cable and you can slave one to the other and have 8 channels.
