Single cam Multiple Mics
Hello
I shot a wedding video for a friend a few months back as a favor. Long story short, several people that saw the end result felt that I should get into this as a side hobby. From what I have gathered, many brides forego the video due to budget constraints. So my plan is to offer low-end videography, making sure that the customer knows exactly what they're getting for their money. I'm in an area where videographers aren't as abundant as photographers and most are booked for the year, so I'm not starving any videographers in my area. Back to the point.... I have purchased 2 Canon HG10 camcorders knowing that audio was their main shortcoming for a camera in its class. What I'd like to do is capture ambient sound along with the lav on a single camera. Can I combine a wireless lav mic with a shotgun mic and jack it into the mic input on the camera? I'm looking at a Senn ew112pg2 and a Rode shotgun mic. I can get both for around $525, but I wanted to make sure that this equipment was compatible with my camera(s) and if I would require additional equipment. If that setup won't work, I was thinking of putting the wireless lav on the groom and capturing the audio from him to the camera. I've seen where people are using a Zoom to capture audio from the lav, but I thought that maybe it would be better suited as capturing the ambient audio. This way I can use the sound from the Zoom to enhance the audio for the 2nd camera. I'm not sure if it helps, but camera 1 would be stationary focused on the bride & groom and the 2nd camera will either be fixed or roaming depending on the situation. Anyway, I would appreciate any help solving my low budget audio needs. Jeff |
Hi Jeff,
Yes you can combine the Senn g2 and a Rode shotgun mic. You have to use one of these xlr adaptors on your HG10. http://www.beachtek.com/prod.html http://www.juicedlink.com/index_file...dio_mixers.htm |
Thanks for the quick reply. Which model should I be looking at on the BeachTek site (DXA-2s?)? Does the Phantom power offer any quality gains over the ones that don't have it? I see where the units are powered by a 9v battery, but the Phantom power consumes the battery faster when enabled.
