Splitting Signal ?
I have a question about splitting a signal and not sure if it can be done, or advised against.
When using my Sennheiser G2 ew100 transmitter and receiver can I split the signal coming from the receiver with a y cable and let both my camera and my Sony PCM D-50 both capture the audio from the handheld mic attatched to the SKP100G2 plug-in transmitter. I dont know if there would be any loss of sound quality, or chance of doing harm to any of the equipment. |
there will be a 6db loss in signal level.
you won't harm the gear. the question is if you wiil still have good S/N ratio. basically if you are getting a good strong level, you will be fine, if you are not, it won't be so good. |
Just be careful that you monitor the sound of both units because the different devices might give you sound problems on both by being connected with the Y Cable. The XHA1 camera you are using has XLR inputs but the Sony PCM D-50 seems to have stereo mini inputs so there will likely be impedance mismatches between the camera input and the Sony PCM D-50 input. Test it out before you get in the field.
Also, in the menu on the receiver unit is an option to change the output level. It is called AF OUT and you can go up to +18dB.
You probably won't have as much loss as 6 dB. The wireless output is proably relatively low impedance and the camera and recorder relatively high. Supposing the receiver output impedance to be 10K and the camera input to be 47K, 82% of the source voltage would appear across the camera input resistor. Paralleling another 47K load across this would lower the developed voltage to 70% of the source voltage. This is a reduction of 1.4 dB
