Sennheiser SK100 wont power on....
I got a SK100 body pack transmitter that wont turn on, i have tried many different battery's and have ruled that out, besides that any other ideas why it wont turn on?
It worked fine about 1 month ago and has been in my pelican case ever since, stored with batteries removed. |
Dear Max,
If this is a Generation 1 model, there is a chance that it is powered on, but the display is blank. Try a fresh battery, then see if your receiver picks up a signal. If you have not changed the frequencies, then it may just work. |
Thanks for the suggestion, but unfortunately still nothing, no display or led lights come on. The batteries are good if i stick them in another device.
Dear Max,
Is yours a "G2"? It is a "G2" if it uses AA batteries. It is a "G1" if it uses a 9 Volt battery. With the "G2", you have an indication, other than the LCD, that the unit is powered on. If I remember correctly, with the "G1" there is no indication that the unit is powered on, other than the LCD. |
its the g2 I have.
