Recording levels in Sound Forge etc
I've been recording dialogue with an SD302 mixer into an SD702 recorder.
All the levels look good on the 302 and the 702, and the sound in the headphones is fine both when recording and on playbeack in the 702 When I bring the file into Sound Forge, the levels look really really low and I have to crank up the gain on the speakers to hear anything. If I increase the gain by 20dB in Sound Forge, the peaks seem to be right around -6dB and it sounds OK through the speakers. Any idea what's going on and why the levels seem so low in SF??? |
I've found I often see that problem when I'm recording, especially going to a digital recorder. It's really hard to maximize the input level on a digital recorder without also peaking out, and as a result we tend to unconsciously set the levels a little lower than we should and compromise by turning up the output of our headphones. I'd recommend putting a compressor/limiter in your chain if you're able. That way you can get the full dynamic range possible without clipping and distorting your audio. Digital distortion due to clipping is impossible to remove in post, so better to be too quiet than not loud enough.
If you're having trouble amplifying your audio that was recorded too low without getting hiss or other white noise, try amplifying using an EQ rather than an amplification plugin. That will allow you to specify the frequency ranges that get amplified, reducing the amount of amplication that happens in the problem frequencies up high and down low. |
Sounds like improper gain staging to me. Do not use the phones to set levels, use the meters, that's why they're there. Send OVU tone from the 302 to the recorder and set the recorders inputs so tone reads -20 dBFS. Engage the 302's limiters. As you record adjust the 302's input faders so the audio peaks around 0VU or a little higher on the 302. That should give you adequate levels with about 18dB of headroom. If the source doesn't have wide excursions in level you could "tone up" at -18dBFS or even -12dBFS to record at a higher average level.
Well, after playing with it some more I think I have an idea what's wrong. Mixer/recorder were set as suggested, but I think I ws a bit"chicken" to set levels high enough. I mainly record groups like brass bands where you need to leave "ample" headroom. With a straight moderate volume normal speaking voice there jud are't such high amplitude excursions to worry about. -12dB worked just fine.
Yes, bad audio frequently tastes a lot like chicken. :)
Regards, Ty Ford |
Or maybe like chicken @@@@ (And I don't mean chicken tenders!) :<)
Actually, the dialogue sounded quite good after bring boosted - better than I deserved! Oh well - live and learn!!! |
Jim,
When I reviewed the 744T (big brother to the 702T), I was asked by Sound Devices to purposely record a track with peaks at -30 and normalize to hear how good the converters were. Yes, there was some noise, but the track was usable. That's scary good. Regards, Ty Ford |
I was quite surprised how well the 702 did in that regard - I think my peaks were around -20 and the result was better than just usable, it was rather nice. I think this says a lot about the value of low self noise in the whole recording chain.
Regardless of which, I'm paying a lot more attention to getting it right in the future. Lesson learned! |
