4 steps to professional wireless mic set-up (video)
I just had a friend come in and do a little demo on setting up a wireless system. The four key points he went over were:
1. Antenna placement, positioning and line of sight (try not to cover the antenna or bend it) 2. Autoscanning for open frequencies 3. Adjusting the Transmitters "Sensitivity" or levels for optimum results 4. Adjusting the Receiver's output level We shot a video to help anyone interested Super high quality Wireless microphone set-up for church, school, corporate, or live event on Vimeo It's also a good chance to listen to the Sennheiser MKE-2 lav. Very crisp, detailed sounding lav. I'm recording using the 100 series Evolution G2 wireless camera mounted receiver into a Panasonic HPX500 camera. It's pretty low noise, I was impressed. |
Thanks, good post.
Thanks, that was a good video.
I have a question, do you still recommend wearing the wireless transmitter with the antenna pointed at the floor? I think you mentioned it in another video, but I can't remember the details. |
Guy, Imagine seeing you here!
**2. Autoscanning for open frequencies Many auto scanners are simply not smart enough. They give an all-clear, but those frequencies may not really be clear, especially if there's an analog TV station on that frequency. Otherwise, good info. And if you do have reception problems, try moving the receiver closer to the transmitter and cabling back to the mixer. Regards, Ty Ford |
The other reason to flip over a belt pack transmitter is that a lot of the time the antenna will get bent when facing directly up (usually by clothing). When you flip it over there is less chance of this occurring. You can maximize your range by making sure the antenna is not bent. Even better if the antenna is not covered by clothing, but we all know that usually doesn't happen. The worst is putting the transmitter in an inside pocket with the antenna all bunched up. Clip it upside down so the antenna is straight down in the pocket, if it's up sticking out, it'll get bent and you'll decrease the range.
