Which format?
Hi Guys,
I have a quick question about my back up audio recorder.I was wondering what is the best format to record in.There are a bunch of options. there is pcm 48 or 44.1khz.then there are multiple mp3 options 320,192,128,64,32 kbps.I'm using it with a audio technica lav.And I'm editing with fcp s2.Any help would be great.I have a shoot tomorrow.Last shoot I just left it on pcm 44.1khz. Thanks! Ryan |
The usual way is to setup for 48khz and 24-bit if you can.
Thanks Jeffery,
Is the pcm 48khz the way to go then? It doesn't give me the option to change the bit rate,but I can put it in 48khz.Thanks again! Ryan |
I'd suggest avoiding MP3 like the plague, no matter what bit rate. The compression can do very weird things to sync when you try to mate it to video. |
Thanks steve!
I really didn't want to use mp3 so I'm glad you mentioned the pcm thing.I'll keep it at pcm 48khz.Thanks for all of the help guys! Ryan |
Hi Guys,
Well I recorded in pcm 48khz and it is bea...utiful.Thanks for your help! Ryan |
