AT822 Stereo Mic with DVX100
I would like a good quality stereo mic to use mounted at my DVX100 instead of its build in stereo mic.
Maybe also a Beyerdynamic EA86 Camera Shoe Shock Mount and a Rycote Softie if they make one for the AT822. Can anyone say something about this setup or maybe recommend a better solution? I like the wide sound from a stereomic instead of a mono mic. I will mix the audio from AT822 with the signal from my ME66 when doing voices. |
I'd recommend the AT825 with XLR connectors rather than the AT822 with mini connectors if you're going to use the DVX-100 and want to stick at this price level.
You'll definitely need a furry type windscreen, the AT825 is very wind sensitive. You'll also need to get a shorter 5-pin XLR to 2x 3-pin XLR's cable. Audio Technica makes one for the AT835ST mic or you can get one custom made. Which reminds me, the AT835ST would actually be a better choice if you really are set on having a stereo mic. However it's a lot more expensive. Some other people on this board use the RODE NT-4, but it is rather large and heavy for camera mounting. I think you could also use a RODE NT-5 stereo pair. This would be fairly inexpensive, would give you 2 separate mics to use and you could vary the angle between the mics if needed. It would require a bit of extra hardware for mounting to the camera though. |
Rycote has a winjammer to fit over the supplied windscreen of the AT822/AT825 as well as the NT-4
For the 822 http://www.bhphotovideo.com/bnh/cont...=258921&is=REG for the NT-4 http://www.bhphotovideo.com/bnh/cont...=277952&is=REG |
