Mixer for A1?
Hi
I have an NTG2 and noticed that the audio contains a hum type thing and it sucks! does anyone know of a good sound mixer for my xh A1? thanks! |
Well man It's like this... I just want to get rid of the hum. I know little about sound. I have energizer batteries in side. Is their anything else that could help?
Thanks alot! |
Your gain could be turned up too high, check your headphone levels - too low of level with your head phone causes you to turn up your mic gain to compensate. Is your hum is static interference, servo motor noise from the focus or zoom? Do you have the Mic mounted directly to the camera or have you tried a XLR cord and move the mic away from the camera? Are you working on phantom power with a battery? Is there a florescent light or a motor nearby? Have you ever had a clean sound with this set up or is it a new system?
Please be more specific to your problem. |
First of all, when and where are you noticing the hum and what does it sound like? Do you monitor your sound with proper headphones as you're shooting and can you hear the hum then or do you only hear it after importing it to your PC for post? Do you hear it with everything you've shot or only some of the time? If you notice the hum on a file in post and go play back the file's source tape in the camera, listening to the playback on headphones, do you also hear the hum? What environment are you shooting in and exactly how do you setup the mic and connect it to the camera, what are the complete details of the setup from start to finish and how are the camera's audio controls set? Is your mic cable a properly wired XLR and have you tried swapping it out for a new one? Are you plugging into the XLR terminals or are you using an adapter and plugging into the minijack mic terminal? Where is the mic physically placed - is it perhaps mounted right on the camera and is it possible the "hum" is actually the sound of the zoom or focus motors? ..... LOL Mark and I must have been typing the same idea at the same time |
If you are hearing something else like a buzz from a florescent light it would be helpful to post a small clip for us to hear. |
Wayne,
are you in manual mode?, are your mic levels set right? Then double-check to be sure that the buzz is really there. The A1 headphone output is not very reliable: got me scared to death more than once, until I realized that the buzz wasn't on the tape, just in the headphones... Best Vasco |
Heres 2 examples
YouTube - test... YouTube - test Exactly what do you set your camera to when your recording audio? |
The girl in the pith helmet is hopeless from your position. There's no way you can get one mic close enough to both speakers when they are separated by that distance. You need two booms to make it work, or I think this scene is one where putting a wireless lav on each of the two main characters and booming the other two would make sense. In the second interview, the voice that says "quit it" at 23 seconds is the only one that sound's actually "on mic." Again, the mic is too far away from the speakers. The hum sounds to me like air conditioner noise - I see a ceiling vent behind the two guys talking, I'll bet there was another one directly overhead. Your tipoff that you're too far and the gain is up to compensate is the level of the two people talking in the background is almost as high as the levels of the two people you're interviewing. You're shooting from down low again, shooting up from waist level, not straight from eye level. Sound like the mic is in front up pointed at them, not above them pointed down at them In both of them the mic placement issues mean you have to crank up the gain to get any kind of voice level on tape. That means everything in the room is also boosted. The distance also means you have a very high proportion of reflected sound versus direct sound in the result. There's no magic setting - you have to use the meters and listen in headphones. I don't recall the FX1 calibration but your levels should have speech hovering around -10dBFS or so, peaks to -6dBFS or so. There's usually a red dot or other indicator on the meter of the proper average recording level. |
Wayne,
2 books by Jay Rose (pick one): - Producing Great Sound for Film and Video or - Producing Great Sound for Digital Video (available used from Amazon for $5!) Best Vasco |
