Deposition Audio Questions
I am in the process of researching the equipment needs of "Legal Video Depositions". I know about the various Certifications, but according to local Court Reporters and Attorneys, not required (Florida). I have also done searches on this forum, and found mostly older posts. Most my questions are regarding the audio, so any input appreciated:
1. Mixer - looking at Sign Eng-44 - 4 inputs enough for me, any other mixers I should research, should I go to 6? 2. Table mics? - already have a couple wired lavs, and need some so called "Table Mics". Are Table Mics really just shotgun mics on a stand? I have a couple Shure SM 86's, but know that you must be really close to the mouth in order to get good audio. Placement would be on a table/desk for attorney's, probaly 3-10 feet distance, what model's would work best? Or should each attorney be laved (read numerous posts where a pain and the table mics should be used). 3. Portable Audio Recorder - read where a good idea to give court reporter a CD. Is it okay nowadays to just give them a .wav or .mp3 file? Or still a good idea to give them a CD? I'm looking at Zoom H2, what do you think? 4. Non Audio - shooting with Sony FX-1 - can't seem to get an answer from older posts. I can output Time/Date thru analog, correct? Anyone else do this with FX1, and had any issues with legalities? Thanks, Rick |
In NY one must be licensed by the bar to do A/V depos... at least to be admissible in court.
I normally use Omnis on desk stands and lavs on the key attorneys & witness'. Video must also have a TOD window burn. |
What you are looking for in a table mic is called a "Boundary Microphone"
Okay, I'm an attorney who takes lots of video depositions.
You will need to mike: Noticing attorney Defending attorney Witness Other attending attorneys who will appear on the record At least one PZM Quote:
I just started doing depositions myself. The Z1U has the ability to record a visible time code, the FX1 can't. The guy who I work for didn't like that 24hr time format, so he uses a program that can read the hidden time code that either camera records and writes in on to the existing footage. Leaves it over night to do its work since its a long process.
He uses the same setup as discussed: lavs for witness and attorneys; boundary mic turned on when the camera man speaks or for when there are more ppl than lavs. He also records to 3 sources: tape, dvd, and portable hard drive. |
I use FX1's for depos. As far as I know you can't directly output time and date from it. I use a program called Visual DV Time Stamp. It's an extra step but works well. Takes about 10 minutes or so to run a 1 hour tape. You can output in either 12 or 24 hour.
Like Paul said....everyone that will be on the record gets a lav. I use an Edirol r4 for audio with an output into the camera....simply because my clients got tired of the opposing attorney rattling papers against their lav mics and screwing up the mixed audio. With separate channels on the r-4 if that occurs you can fix it. Mark |
<<It's an extra step but works well. Takes about 10 minutes or so to run a 1 hour tape. You can output in either 12 or 24 hour.
Like Paul said....everyone that will be on the record gets a lav. I use an Edirol r4 for audio with an output into the camera....simply because my clients got tired of the opposing attorney rattling papers against their lav mics and screwing up the mixed audio. With separate channels on the r-4 if that occurs you can fix it. >> Both of these are o.k. ideas, but involve post-production. I believe that could actually call into question the accuracy of your depo, because it has been "altered" after the fact. Yes, I know we all recognize you are not changing anything, but once you make any change, it could send up a red flag. btw I'm not an attorney, so that opinion is strictly my own. Besides... as far as audio, it's much easier and part of the job to actively mix the 4 or more sources during the deposition. Believe me, I feel your pain on attorneys rattling paper, or chewing on something, or sitting their portfolio in the lap to look for something, thus propping the top of it right against your lav! But I believe you can and should take care of it "live" rather than having to do post work. The time code can also be done live. Even for cameras that do not output time and date, you can buy a time code or time/date generator. Horita makes several of these products. Then you run your video out of the camera through the time/date generator on its way to your DVD recorder or DV deck or whatever you are recording on. An extra step I know, and means your camera tape doesn't have the time/date, but it can be done. Lots of ways to skin a cat. Have fun! |
Hey Rob.....totally with you on the altered aspect. I basically use the r4 as a mixer....I run an out to the cam and always use the cam audio. Only if the attorney asks do I do anything with the audio......then it's on him the way I look at it. Then I can isolate because I have everyone on separate tracks. And yes....they pay if they want it fixed......so in essence the only extra post work I do is the time date stamp.....but that's just 10 minutes or so of computer time. I can always find something else to do then!!
Mark |
Mark,
That's a cool idea then on the 4-track. Nice to have if you need it. Rob |
