High-Isolation Headphones
I was covering an outdoor live band for the Chamber of
Commerse. It'll be part of a promo to get people to come here. Anyways, I was in the field with my Sony 7506s. I've always felt that these are not particualarly good for blocking out the surrounding noise, but in front of that band I couldn't even use them because the band was overpowering. Are there any accuarate headphones that would be a big leap up in isolation? Of course, a main concern in this type of shooting environment is distortion, so I need headphones that will allow me to monitor. Just as a post script, I was going line in to a VX and had the pre-amp set to very minimum boost, which I believe is 6 dB, and the pre-amp limiters were *still* activating. |
The Remote Audio cans are pretty well an industry standard, and are very, very, good.
For me, I prefer to go the other route, isolating in the ear, rather than outside. This isn't *quite* as good as iso-cans like the remotes, but a heckuva lot lighter in weight. Cost is slightly higher though too. http://www.etymotics.com Look at the ER4 and 6. I carry the 4's with me everywhere I go. |
Never heard of those HN-7506s before. I wish they came in black.
I nomally wear dark clothes to more blend in while I'm working. Anyone have any ideas in a black headphone. |
You could also try some industrial strength ear muffs that will fit over the phones.
Aaron |
Maybe this will be a "Mr. Obvious" statement, but just in case anybody doesn't already know... The Remote Audio phones are aircraft headsets with 7506 guts. If somebody felt inspired enough they could pick-up some used Sigtronics headsets for $50 and pop in the guts of their 7506's...
When I used to fly I always thought that would be a good idea with my David Clarks... Bose makes some really high-end aviation cans, but I don't think an active cancelling system would be the ticket for random noise... it's more for droning sounds that can be phase cancelled. UPDATE... I tried to find the best price on new aviation headsets and for anything new you'll be pushing $100... $80-$90 at the lowest... When you combine that cost with the cost of the 7506s the Remote Audio phones start looking pretty attractive... |
Spot, that etymotics.com link appears to be a placeholder portal.
Also check out http://IFBSource.com for other in-ear monitors. In-ears are gaining popularity as lightweight, high quality audio monitors with very high isolation if used with custom ear molds.
Another more common choice is the Sennheiser HD-280 Pro headphones. Similar in design to the Sony 7506's, though larger, they are more robust, have a better headband, more durable cushions, a smoother frequency response (especially in the low end), and MUCH better ambient noise isolation. They are cheaper too. Caution - Creating the Remote Audio HN-7506's took a bit more than just placing the drivers in an aviation headset. It took them quite some time to get them to sound right. |
