DC Adapter for g2 reciever??
Is there anyway to hook up one? Anyone ever come up with a way to make one... I'd think it wouldn't be too hard (9v would be easier).
I need about 8 units and I figured I'd get about 3 with the camera mount recievers for other uses at times. Since half the time I wouldn't be needing them wireless I'd like to have them hooked to an adapter. Any ideas? |
A DC adapter is availabel from sennheiser. It's the DC2 and it takes anything from 10.5 to 16 volts. See: Sennheiser | DC2 - DC Camera Power Converter | DC2 | B&H Photo
I must admit I did not quit understand the full question. If you want to connect the transmitters/receivers to the mains the DC2 still would be useful, combined with a cheap 12 volt power source (DC of course). Stabilization takes place in the DC2.
Sorry for any confusion... that is it completely... but not at $60 bucks... that's just insane. $60 for a faux battery and cover. I guess it works for those looking to connect it to an Anton's type of system. But, yes I want to connect it to mains, not just another battery.
So, I'll probably just make a faux battery and send it 3 volts myself. Thanks for the info either way. Any DIY'rs do this yet? |
And $60 sounds pretty cheap to me for a professional adaptor that sells in low quantaties which comes complete with replacement battery door, replacement hinges and cable. To run from the mains, use teh NT 2 power supply and connect it to the cable from the DC2. |
I agree, IF, as I said, I wanted to hook it up to another battery system on my camera. But to just hook up to mains then it's just one piece of the puzzle and is just added expense and circuitry.
If you are hooking up to mains all you need is a dummy battery and a PSU that puts out 3v. No need to waste all that energy (and money) getting to 12v then converting again to 3v. |
Why not just buy the non-portable table/rackmount recvr.s and be done with it. If running on A/C is desired.
Rick, because sometimes I want camera mount... but not always.
Well, I would say build a faux battery and wire that up to a larger well built supply that could power them all on. And money is still an object.... just because I'm spending 500/unit on these doesn't mean that might be a good chunk of the budget. The wireless mics are just the heart of the system and needing so many is why I'm looking at the G2's. |
My G2s' will run 10+ hours on a set of rechargeable hybrid batteries. (Longer if I shut them down for lunch)
The cheap and easy option IMO. |
