Plugging in phantom powered mics
I've seen some instructions that come with phantom
powered mics say that you should plug them in before applying the phantom power. In the past, I've plugged in mics with the power already applied and have not noticed any problem. Does anyone know anything about this? Do you always wait till they're plugged in before hitting the power? |
I try to wait to plug ANYTHING in only when the power is off. I would guess a mic is a sensitive instrument, so I try to use that rule for mic. I admit I don't always remember. I doubt it is a binary decision, but more one of each time causing a little bit of extra wear and tear on the diaphagm until one day you wonder what happened to your microphone.
It's definitely better to plug and unplug any mics when phantom power is OFF and the system volume controls are down.
Even dynamic mics will cause a loud pop through the system if phantom is on and you connect or disconnect. As was stated earlier, it usually doesn't kill anything right then, but it's needless stress on the mic, preamp circuit, mixer, amp and speakers. Don't forget that when turning phantom off it still takes several seconds for all the power to bleed down. |
Thanks, you made your money today...take the rest of the day off! |
this will probably never come up for you, but phantom power can kill ribbon mics. (it won't hurt any other non-phantom mics.) there aren't any ribbon mics you'd use in video production, but they are used in the rcording world.
Ribbon mics are coming back into favor though, so running into one when shooting in a music environment could be more common than it was.
I wonder what would happen if you accidentally sent
48V phantom to a wireless receiver? |
It depends on how the connection is wired, how robust the phantom power circuit is and how robust the receiver output is. The effects range from nothing wrong happening to something burning up.
If the receiver uses a balanced connection, then usually there is no problem with something frying. Some devices don't like having phantom sent into their outputs and either their audio or metering is affected but nothing is damaged. Some receivers use various forms of unbalanced outputs and that can cause a problem, usually shorting one leg of the phantom power to ground. That can burn up some phantom circuits. Usually there is a caution about this in the operators manual if it is susceptible. |
