How to remove specific sounds from a video ? ? ?
The content we shoot requires us to have a still cam on burst mode during a critical portion of our videos. We are trying to learn a good way to eliminate or at least minimize this sound in the video without replacing the audio as we really need original (real) the sound track from the talent in the video. Is there any audio editing secret that would help us accomplish this?
We edit in Premiere Pro CS3 Thanks! Bill |
iZotope RX, Soundbooth, Soundtrack Pro... those are the applications you should be looking at. iZotope is probably your best option. It won't be very easy though.
My personal preference would be to shoot several takes of two versions, some with the stills camera operating, then some with the stills camera not operating so the actors "pacing" remains the same, then perhaps copy over the dialogue or background sound in post. - It is likely that in edit, the insertion of "burst-mode" stills may require some time stretch or cut, so a background ambience would be good to have as well as the "stills cameraless" takes. - More options is all.
Blimping is good, with Steve on that.
Is there no still camera that can burst without making a lot of noise? However you solve this problem, it will take much less time and the eventual soundtrack will be of better quality if you can somehow avoid recording this sound, rather than trying to take it out later. There may be other issues. For example, if you are on automatic audio levels with a camera mounted mic, and the stills photographer is next to the video camera, that's probably the worst possible setup for this issue. (mic is closer to the still cam than to the subject, auto tends to pump up background sounds.) |
Is what you're worried about the "clunk" sound of the mirror rising and falling? How long are the bursts/ how many frames in a burst? Can the mirror be locked in the up position if this is the issue?
I think Izotope RX can probably do it well, but getting this kind of noise out is usually labor intensive, ie you have to find each instance and apply appropriate reconstruction and if the noise re-occurrs continuously there may not be enough "noise free" content betwen the noises to make it work. So it might be too labor intensive to be practical if you're dealing with dozens of occurrences. Sort of like audio rotoscoping I guess! Strange thought - maybe it would work by calling the continuous dialogue "noise" and "removing" it to a new file. I've done things like that in the past with RX and they've worked, but whether it would work in this case I couldn't tell without trying it. Do you have an example you could post a link to? I'd be happy to take a shot at it, but without hearing what it sounds like I'd tend to agree with the other posts that the best way is to keep the noise out of the track in the first place if at all possible. Here's a link to a before and after example of something I just did with RX http://www.dvinfo.net/forum/all-thin...rx-i-love.html |
As a follow up to what Steve just said, some of the newer cameras (Lumix four thirds etc) don't have mirrors at all. They also tend to be cheaper than Leicas (maybe 10% to 20% of the price!}
Is the stills camera actually in the shot as part of the story. If not could you not simply shoot with a second video camera the same scene from the SLR camera POV, extract the appropriate frames and insert them into the edit as faux stills.
If the sounds that you are removing are all similar, try doing a time-frequency selection and using a "Find Similar Event" feature of RX.
Rather than look at broad-band noise removal, another approach is more narrowband filtering and EQ. Motor drives are buzzy-sounding, making them somewhat broadband noise sources, but the mirror slap and/or motor noise can be isolated if you have a good spectrum analyzer (the Channel EQ plugin in Logic and Soundtrack Pro, for example, or any number of 3rd party standalone apps). You won't eliminate it, but depending on the rest of the audio track (which you've not described), you can minimize its apparent volume.
It also depends on what other production audio you have going. Can you get mics on a boom closer to the talent? Can you opt for more directional mics (cards, hypers) that point away from the motor drive sound source? Use wireless lavs on the talent? Cover the top of the camera in furniture moving blankets (that's no joke, totally typical techniique)? Multiple options of the above? If you have any latitude in this regard, it'll be way better than anything you try to do in post. |
