Two Cams One Mic
Any recomendations for a quality mixer that will send the audio signal from one mic to two video cams?
[QUOTE=Scott Ellifritt]Any recomendations for a quality mixer that will send the audio signal from one mic to two video cams?[/QUOTE
Are you planning on recording on 1 channel in each video camera or putting the same signal on both channels of each camera? Battery operation or mains? |
Thanks for the response. I want to record both channels on each camera.
Battery op preferred. |
I may only need an XLR splitter. Is there any noticable signal loss or interference?
Thanks. |
http://www.behringer.com/MXB1002/index.cfm?lang=ENG |
Thanks Steve.
I use a mains powered Behringer 20 channel board quite often to feed two tripod mounted cams. Line out from the XLR or 1/4 inch jacks. Works great!
Yes. The Sound Devices 442. It has four inputs, two separate balanced stereo outputs, a third steeo unbalanced output and a mono mic level output. I feed two cameras (and my laptop) the exact same audio simultaneously all the time with it. It's truly a beautiful sounding piece of gear. Regards, Ty Ford |
You mention you're feeding your laptop as well. What are you using as the audio interface there? Have any suggestions for a quality audio interface for a desktop that is going to be used as a video editing and audio recording/editing/mixing workstation but not so much for music creation? |
Hi
Any mixer that has outs will do. I would personaly use a mixer with "aux sent" , most of them have two "sents" so its easy to control your output. Anthony |
Hey I just remember what I did on a similar situation with audio gear. Maybe you can apply it here.
Feed one camera, take the phones/line out and sent wirelless (or cable if you can) into the next camera. You will only need good head phones and yous eyes on the levels. Anthony |
However, any camera you don't listen to is a possible disaster waiting to happen. If camera 1 screws up and that screwup is sent to camera 2, you're cooked. Work arounds are just that and there's always the price when the something doesn't happen just the way you expected, which is most of the time. Regards, Ty Ford |
There's also the SoundDevices 302. Balanced XLR outputs for the right and left channels and an unbalanced stereo output. You would need to attenuate the unbalanced output to get it down to mic level though. Since you apparently only have one mic, couldn't you just use the stereo output of any mixer and feed the left channel to one camera and the right channel to the other? Your XLR adapters (which you will need anyway) should be able to send the mono signal to both channels on the camera.
I have a Rolls splitter by the way that they claim doesn't degrade the audio at all, and to my ears they're right. That would be the cheapest route. |
