Mic's for HV40, film short
I'm looking for a decent shotgun mic to capture dialogue. I've been taking a look at Rode microphones, but I just don't know enough about them to find any difference in quality and what not. Anyone have advice?
We put together video kits for reporters at the newspaper I just retired from , HV20's with the Sennheiser mke400: Sennheiser | MKE 400 Compact Video Camera Shotgun | MKE 400
This is a remarkably capable mike for one it's size. It is scaled nicely to fit the HV40 camera --- if you plan to use it on-camera---a larger mike will overhang your lens and get in the way. And it plugs directly into the 1/8 inch mike input on the camera. You can, of course, get a Beechtec or equivalent XLR interface and use a larger mike --- the Audio Technica AT875 is a good size, if your interface provides phantom power, or the AT897 which will operate on an AA battery, might be a good choice, but again, out of proportion to the camera for on-camera work. The Rode Video Mike gets good reviews but again, is rather large for this application.... hth / Battle Vaughan |
Hi Battle
Thanks for this tip. The MKE 400 Looks like a very useful compliment to HV40.
Regards, Pavel |
Yes, Pavel, we found it to be a very nice on-camera mike. It is surprisingly small but does the job nicely, fits the camera, the accessory shoe and the mike input to a "T". /BV
The NTG-1 is a step up in quality, but uses phantom power so complicates the setup. The NTG-2 has a battery option but that makes it even longer. Care required to avoid getting in shot. Both would need a SM-3 or similar shockmount. Neither are particulary good where there is wind, even with the deadwhatever fitted. You need to tape up the xlr socket and the switch and/or get the full blimp to be reliable outside. Also an xlr to minijack cable is required. Top of the range is the NTG-3. Phantom power only - needs a supply. Great mic, but probably overkill for an HV-40. I use an NTG-2 with HV-30s because I had one for use with an XH-A1. |
I really appreciate the help you guys. Slowly but surely i'm learning this mess, and honestly Steve I agree with you. I think a mounted camera is out of the question. My cousin and I were actually talking about this. I want to eliminate that 'humming' noise as much as possible, so I think a shotgun is my best bet. Once again thank you guys so much for the advice! I'm using it so much lately
Shotgun-Outdoors
Hypercardioid-Indoors Remember the pickup of the dialogue is most important. As Steve House mentioned you want to get as close to the subject as possible. So booming or a stationary boom close to the subject is your best bet than having it on an actual camera. If possible try using a mic mounted on your camera to record your cousin and then put the mic on a boom closer to your cousin and tell me which you like better. Nicole |
