New Audio Setup - Any forseeable problems?
I just started testing a new setup and wanted to seek feedback (see attachment below). It is an H4n and a Rode NTG-2 both plugged into a JuicedLink CX231, which feeds into a Canon T2i using Magic Lantern. I tested it a little last night. I think it will be useful at wedding receptions, where a shotgun would be useful for interviews while drowning out the background music, and the H4n would be useful to capture the other live sound during dancing, etc. Being able to monitor using Magic Lantern levels/headphones will give me a good idea how I need to balance the two. Anyone else using a similar setup? Any other forseeable issues that may cause problems on the fly?
http://www.dvinfo.net/forum/attachme...s-img_0425.jpg |
Re: New Audio Setup - Any forseeable problems?
How exactly are you connecting the output of the H4n to the Juicedlink?
The H4n just has a line out (mini) to my knowledge, which runs into the 2nd balanced XLR line of the JuicedLink.
I'm clearly a novice with audio, but it's hard for me to tell - the entire cord is wrapped up in one piece (I'm used to seeing each of the three wrapped up separately if that's what you mean).
Sorry again - I'm embarrassing myself my with limited audio vocabulary! I'll look into getting a multimeter. Here is the cable I have (came with my Senn. G3).
http://www.bhphotovideo.com/c/product/233893-REG/Sennheiser_CL100_CL_100_1_8_M_Mini_to.html |
Thanks Steve. After a couple times testing, I've been able to verify it's a mono signal with mixed stereo channels. I've got the H4n set up at 120 degrees now instead of 90, which will help get a wider pattern. I'll put it through a bigger test Saturday at a wedding.
