Sennheiser G3 diversity receiver performance?
I've been using a Sennheiser G2 wireless system for a few years and am thinking of getting another channel. The G2 system works quite well most of the time. I have been surprised at the number of multipath dropouts. That's my only complaint about the G2, really. I realize there are better systems, but not in my budget.
For those of you using G3s, how well does the diversity receiver work in practice? Is it a real, noticeable improvement over the G2? Brett |
Re: Sennheiser G3 diversity receiver performance?
Check squelch level - normal setting should be "low". Check the transmitter antenna as a transmitter touching the skin can lose you about 70dB of transmission power. Even 1cm off the shin gets back most of this loss. But, yes, the diversity EK 100 G3 will be better as to multi-path mutes. |
However I have wondered and will welcome everyones' comments on this: Photos of the G2, G3 always show STRAIGHT antennas. My antennas are flexible, and they flop and curl around a bit. I was considering straightening them with something plastic and less flexible, like a small tiewrap or spray can extension tube to see if fully extended antennas make a difference (it should). What are other user's antennas like in normal usage ? It could also be that I was using 'clear', but not optimal (noise-free) channels. Does anyone know of a directory for Canadian cities for best frequency use? Quote:
Thanks for your ideas, and esp. the reminder about keeping the Tx antenna away from skin. Brett |
[/QUOTE]
However I have wondered and will welcome everyones' comments on this: Photos of the G2, G3 always show STRAIGHT antennas. My antennas are flexible, and they flop and curl around a bit. I was considering straightening them with something plastic and less flexible, like a small tiewrap or spray can extension tube to see if fully extended antennas make a difference (it should). [/QUOTE] I've seen some folks use rubber tubing around the Tx antenna to help keep it off/from touching the skin, seems definitely worth a try. |
But, personally, I use radiomics as little as possible as my main recording is classical music recording for CD release. I have used radio, but mostly G1 and G2 - but as you are getting multi-path the G3 would be better as you do have two antennas and the second antenna is always at a different angle, which improves things. How much better I can't say - you will need this from someone who has used both G2 and G3 in anger on a shoot - which I haven't. |
