stereo recorder for around 400 $ as spare audio recorder on location
i need a spare audio recorder to bring with me on location, (something that save my pay and my working day in case my recorder fails), and for general use where i may need a stereo portable recorder.
is anyone of you using tascam dr 100 or fostex fr 2 le? what are your opinion? about preamp and batteries? |
Re: stereo recorder for around 400 $ as spare audio recorder on location
I don't have any experience with the two you mentioned, but as far as I've experienced, the Zoom H4n ($300) certainly seems to be the standard field recorder in that price range. I mostly come from the DSLR circles, so I don't know if there's other popular recorders among other circles...
Another good unit is the new Zoom H2N and I think it may be less expensive than the H4. I have had experience with the H2 & it is excellent.
RonC. |
H4n is worth the extra money. I've used both. Only quirk I have with the h4n is the battery life. There is a stamina mode but you lose a couple of features. Doesn't seem to affect recording quality.
The Tascam stuff looks good too. They are generally good quality. |
Ben, the H2 & (N) does not have XLR but I would think that the whole purpose of these devices is good quality with simplicity as the built in mics are surprisingly good for most purposes and there is no fiddling with cables or connectors. I have only used the front mics and have never used the surround feature.
However, I have only used the H2 and assume that the H2N is as good or better and for a surprisingly small amount of money considering what you get in the package. RonC. |
In the market place I work the H4n has become the (default) recorder for DSLR work. Clients expect a H4n to be used... a colleague of mine has a Sound Devices 788 and did his first DSLR shoot recently and was asked why he wasn't using a H4n because that was in the spec sheet for the production, despite the 788 being WAY superior.
anyone know which is the least expensive portable digital recorder with 4 XLR inputs?
or does the Tascam DR-40 allow the recording of all the inputs - XLR and 1/4" - at the same time? (edit) I just looked at the owners manual for the Tascam DR-40 - http://tascam.com/content/downloads/...r-40_om_va.pdf - and the 1/4" inputs are actually in the center of the XLR inputs - so you can only use two at a time... :( (Edit) I just remembered that I have an old analogue Tascam mixer that I couldn't sell. I can run my 4 microphones into that, and then the output into the 2 channel Tascam DR-40. Yeah for me. (edit) My Tascam mixer doesn't have phantom power for the mics... too bad for me... |
anyone know which is the least expensive portable digital recorder with 4 XLR inputs?"
>> Off-hand I would say the Roland R-44. However, in that price range, the 8-track Tascam DR-680 is another option, w/(6) mic pres , (4) XLR/1/4" (combo) mic/line inputs and (2) TRS 1/4" mic/line inputs The 4-track SD 744 only has two XLRs, if that's of interest. does the Tascam DR-40 allow the recording of all the inputs - XLR and 1/4" - at the same time?" >> No, The DR-40 uses XLR/1/4" compo jacks so it would be physically imposable. (AFAIK, you can't split the L/R inputs either, for instance Left=mic; Right=Line either... and there's no separate L/R record level offset. (which may be added later in a firmware update) The alternate 2-tracks are for the internal mics or reduced level safety tracks. (-12dB ) |
im between Dr 40 and H4N
gotta decide this urgently main purpose is using with 7D and Epic-M for non prof. works |
Tascam just released the DR-100MKii for $329 which looks like it might be a good one. 2 XLR inputs and supposedly they finally allow line level inputs.
