Can wired lavs be hooked up to mic processors?
I am considering buying a pair of either AT-899s or Shure MX184s to use in the field. However, I am wondering if I could also use them in a studio setting instead of current radio mics we use, which we connect to a mic processor, specifically a dbx-286a. Would this sound good or should mics of this type NOT be connected to a processor?
Re: Can wired lavs be hooked up to mic processors?
Technically, any microphone with a conventional XLR connector can be plugged into the DBX-286. That would appear to include the AT899 (assuming the standard XLR option) or the Shure MX184 (again, assuming a standard XLR connector version). Most lavs (including the AT and Sure models you mention) require phantom power, but the DBX-286 provides phantom power.
A Phantom Power adapter and /or battery adapter can be purchased for most wireless mic plugs, however they ain't cheap. For instance the Tram TR-79 is $170+. This an extreme case, but it will still cost at least $50 for a RODE or OST.
If you are asking about lav mics that can be used with BOTH wireless body-pack transmitters AND with conventional XLR inputs, then I highly recommend the Rode Lav mic. It not only has a field-replaceable cable, but also field-interchangeable connectors for either XLR or wireless use.
Also available as a headset mic with the same features. I like mine so much I am buying another 1 or 2. Rode's interchangeable connectors (including phantom-powered XLR) are VERY inexpensive (US$25) in comparison to the vastly overpriced adapters other vendors try to foist on us. |
Lav mics typically require low voltage power (in the range of 6V) from the wireless transceivers. This means they won't work with the 48V phantom power typically delivered XLRs on mic processors. Not to mention the different connectors.
I second the Rode Lavalier as a very flexible system with a good price for good sound. |
Your question is incomplete and impossible to answer. Those microphones are available in versions and there is no single answer possible that covers all the versions.
If you are asking about the XLR versions of those microphones, then yes, you can connect them to a mic input with phantom power. Indeed they likely REQUIRE phantom power (or else an internal battery). If you are asking about the wireless body-pack transmitter version of those microphones, then NO they DO NOT operate on the kind of "P48" phantom power you see from an XLR input. There are adapters available for SOME microphones that allow a wireless-style lav mic to be used with an XLR output (and P48 phantom power). And there are the Rode lav and headset mics which are designed with interchangeable connectors for either the wireless transmitters or for direct connection to conventional XLR inputs. |
I always try to ask incomplete questions that are impossible to answer.
I was referring specifically to the WIRED AT-899s or Shure MX184s that work with phantom, and whether they could work with the DBX-286. I take it from your response that the "low voltage power" you mentioned only applies to the wireless use of the mics, given the electrical characteristics of the transmitter and receiver. |
Since you seem to want only a simple answer: NO microphone that is wired and connectored for wireless use is compatible with an XLR mic input with phantom power. There appear to be no options for either the AT-899 or the MX-184 that are compatible with XLR and phantom power.
Steve, the question seems to be about simple interfacing, not processing.
Virtually all wireless body-pack transmitters use 3.5mm or Lemo or QG connectors or similar miniature connectors. Clearly those connectors cannot be used with conventional XLR mic inputs. |
http://www.bhphotovideo.com/c/product/126755-REG/Shure_MX184_MX184_Supercardioid_Wired.html http://www.audio-technica.com/cms/wi...8dc/index.html where if you look at the specs under "Included Accessories" it says the mic comes with an AT8537 XLR power module BTW Natan, the Shure MX184 you mentioned is a supercardioid pattern mic. That's really more for sound reinforcement applications where feedback control is an issue. The downside of a directional pattern like that is the timbre of the voice recording changes as the subject moves his head. An omnidirectional mic, the MX183 in the Shure lineup, is generally preferred for film and video recording |
"Clearly those connectors cannot be used with conventional XLR mic inputs" and furthermore, if one attempts to apply Phantom Power via hardwired adapters or adapter cables, the mic could be permanently damaged. As I previously stated the only way to use a lav which is wired for a body-pack transmitter or other "plug-in power' device is though a Phantom Power transformer specifically designed for the mic. For instance, the 899 would need a AT8537 In-line type power module.
