Mono Minijack into stero input- No problem?
Wondering if I connect a shotgun (mono) into a GL 2 ext mic input (stereo) if things will work ok with no damage (shorting out etc). I realise that I will only get the one channel of sound......
You need some kind of adapter to route the signal to both channels. Otherwise you're likely to get interference problems. I don't think you can do any damage though. Try this:
http://www.bhphotovideo.com/bnh/cont...ughType=search Double check with B&H that it routes the signal to both channels. It would be better to use a transformer balanced XLR adapter though. There's lots of options for that. |
No damage worries, and I wouldn't expect any interference. But like Marco says, it's very cheap and convenient to record the mono to both channels.
If I'm only using a mono shotgun I usually just plug it straight in and only record to one channel, then when I edit I just the clip to left channel only (or whatever) in Vegas - I hate having innecessary adaptors due to more posible bad connections, and greater susceptability to hum/interference, etc
Colin,
Indeed, you won't damage your camera by plugging a stereo mic into a mono input. And unless you have a stereo mixer taking a double right/left channel feed to your camera you will only get a mono audio feed anyway. Therefore....not an issue. Sincerely, Stephanie |
