Which would you buy?
I'm trying to choose a mixer and wondering if 3 or 4 channels will serve in the long run. Slowly getting into wildlife video making. Most often I'm solo so it is challenging but really fun.
I can't decide if the 4 channel is worth the extra money and weight. For a 3 channel the Azden FMX 32a is appealing. Using a Canon XA10. The things to mix are 1. ambient sound, being captured with a sony stereo ECM-MS2 2. my voice live, via an unchosen wireless lav 3. (sometimes) distant sound using some mono device If a mono shotgun is used, I wonder if the stereo mic would best be disconnected since the focus would be on sound originating farther away. However the resulting mix (with my voice) would be mono. When needing the shotgun, would it make sense to have a mono mix of my voice and the shotgun? 3 channel mixer would do. On occasions when distant audio is needed, would the result be better with a mix of my voice, the shotgun and the stereo mic (4 channels)? |
Re: Which would you buy?
You didn't mention any sort of budget. If you are looking at Azden, then it appears that you are scraping the bottom of the barrel.
It isn't clear to me what benefit something like that Azden mixer would provide for the $$$? I would not expect that the mic preamps in the Azden are of any significant better performance than what is in your camcorder. If you are recording ambient/nature sounds you want to be going for equipment (specifically microphones and preamps) that have better than average noise performance. Azden would be my last choice for that requirement. ECM-MS2 is not noted for being a low self-noise microphone, either. But I guess you have to start somewhere. Note that there are online forums specifically for nature recording where they discuss the kinds of mics and other equipment users have found to give the best performance for the $$$/ |
Would you say which forums? My impression of dvinfo is that there are tons of expertise and activity.
The XA10 only has 2 xlr inputs, so the mixer is intended to add another channel or two, not somehow improve the audio beyond what the camcorder can record. If they are roughly equivalent in quality as you suggest, then they would be a decent low end (as they now feel) match, no? Quote:
Didn't we go through most of this in a thread you started a little while ago? Or is a case of you just didn't like the answers to your questions so you thought you would have another try?
http://www.dvinfo.net/forum/all-thin...rnal-mics.html |
A 3-channel mixer is not going to do what you described... Sony stereo mic, that's two channels. Mono lav, that makes 3 channels. "Distant sound using some mono device" makes 4. IF you want to mix all those sources together to a stereo output, 3 channels won't cut it. Not saying that it makes sense to do that mix in the field, especially if you're trying to operate the camera as well, just that assuming you were going to try, a 3-channel mixer won't suffice. Why a wireless lav on yourself? Lav yes, but there's no need for the expense and potential reliability issues of wireless. Unless there's the true need for mobility on the part of the subject without the encumbrance of a cable, hard-wired is the way to go. Static setups don't need wireless. Be aware that mixing of various sources in the manner you seem to want to do is usually done in post, NOT while recording in the field. This is why they make multichannel recorders. Once mixed, you can't un-mix 'em, so if you mix during recording there's no going back if it turns out it doesn't sound right when you review it back in the editing bay. If the mix doesn't work, your only option is to go back out and reshoot. |
You keep coming back here asking questions about how to implement a production process that none of us think will work (based on first-hand experience). I don't know what kind of answers you want from us. |
The question about the 4 channel comes from this. I don't think I need the stereo sound when recording something at a distance using a mono shotgun or something. That leaves mono voice and mono far off subject. Afraid they will mix to a dull sounding mono. This is the crux of the 3-4 channel decision. If it will sound ok, the 3 will do (lighter, cheaper too). If not (true stereo needed at a minimum for aesthetics), then I need the 4 channel. Is there any field mixer worth using (by way of compromise in quality) under $500? Once I learn post production, it will be incorporated, but my vids are hands on and so I need the live vocal track. I am open to hardware suggestions (and would very much appreciate them). The wallet constrains though, so quality reduction and doing nothing are the only choices. |
With one lav and a one mono shotgun (or other mono mic) Those tracks could be recorded on separate tracks and mixed in post.. (possibly using a mono-to-stereo simulation plug-in.. but that's for another thread altogether) So two channels and tracks would work in that configuration. If you record the ambient with a 'stereo' mic, which uses two channels, than a three channel mixer would be needed. (two for stereo ambiance, and one for your narration.. this configuration would have to mixed at the time of acquisition.
1 Attachment(s)
If I'm handling a live arthropod, reptile or picking apart a plant in the field and talking about it, how would post production audio overlay what I am saying live? Yes it is multitasking, but the XA10 makes it very do-able. Are you saying "No I can't do that!" What the heck? Maybe you are assuming that this work is some sort of avocation and that I should not submit work that is less than professional in quality. I'm a naturalist, not contracting with anyone. Thanks Rick. Just saw the pseudo-stereo plugin at Audacity. Not sure how it sounds but they're saying its a heck of a lot better than straight mono playback. That means a 3-channel will work. Appreciated : - ) |
So if I can afford a max of 500 for a field mixer, you say don't us it to mix more than 2 channels because it is not as good as I can make it? I'm not stuck on Azden, but without a suggested alternative... I don't see anything, even used that offers a significant improvement in that price range. |
" its a heck of a lot better than straight mono playback"
- Only in certain instances... depends on the audio. A pseudo-stereo effect would probably work on atmos' and such, but narration should be mixed dead-center in the stereo field. Not familiar with the Audacity FX. There's other free stereo simulation plug-ins as well. Search and you shall find. ... As I recall, the 'Sheppi Spacial Enhancer' and 'Voxengo Stereo Touch' are decent on some material.. Both are free VST (PC) plug ins. Warning, a little goes a long way. Mono compatibility should always be checked as well.. but that applied to most everything |
Well this is all really helpful. Lots to think about. Thanks! Now to turn what would have been some lousy recordings into less lousy ones :-)
