Yamaha C24 vs Yamaha 2G at DVinfo.net
All Things Audio
Old May 15th, 2013, 02:43 PM   #1
I ordered a Yamaha C24 and received a Yamaha 2G instead. Anyone know the difference? This device seems very cheap, but I do not feel like exchanging if it won't make any sigificant difference for my use as a lav mic recorder.
thanks in advance for any insight you can offer.
Old May 15th, 2013, 03:21 PM   #2
Re: Yamaha C24 vs Yamaha 2G
Another question about these units...will a lapel microphone need it's own power with these units? The Zoom H1 does not require a powered mic, and I want the same feature in whichever voice recorder I buy.
Regardless, I am returning the Yamaha 2g, I have found it is significantly older model than the C24. The G2 records at 16 bits instead of 24 bits, for what difference that makes.
Old May 15th, 2013, 03:35 PM   #3
From what I see, they're similar. The C24 is a 'newer' model, but 'discontinued' according to B&H. Alternately B&H states the 2G as 'unavailable'.. which I would assume is also 'discontinued' since it was released two years earlier.
http://usa.yamaha.com/products/music...ion/recorders/
See the Yamaha website for features, specs, ect. and you decide.
I would take umbrage to the substitution if not notified and/or given a nice discount.
Pocketrak C24
Release Date : 1/2010
World’s smallest and lightest recorder (2oz./57g with battery)*
24bit/96kHz recording capability
2GB internal memory/Expandable with High Capacity microSD Cards
Onboard Speaker
Two Great Practice Aids: Built-inTuner and Metronome
Peak Limiter for Optimum Music Recording
5-band equalizer lets you tailor the playback sound for optimum response.
High-pass filter automatically reduces wind noise and low freq rumble.
Attachment clip included\
Pocketrak 2G
Release Date : 2/2008
Only 1.7 ounces and 1/2 inch thick -take it everywhere!
2GB memory for high audio quality and extended recording times
High-sensitivity tilt-up microphone
Level meters and ALC for optimum record levels
Long-lasting rechargeable battery
Direct USB 2.0 computer connection
CUBASE AI digital audio workstation software included
DRM10 playback support and comprehensive playback functions
Old May 15th, 2013, 03:47 PM   #4
Originally Posted by Jeff Harper View Post
Another question about these units...will a lapel microphone need it's own power with these units? The Zoom H1 does not require a powered mic, and I want the same feature in whichever voice recorder I buy. .
Every portable recorder I've seen in the last five or so years that has an unbalanced 1/8" mic input have 'Plug-in power'. This includes cameras.
Old May 15th, 2013, 07:12 PM   #5
Rick, thank you kindly for the research! Glad to know this about voice recorders regarding the plug in power. I know squat about recorders and this was a concern, as I had a recorder a few years ago that did require a powered mic and it was an upleasant surprise.
Old May 16th, 2013, 05:28 PM   #6
Jeff, I too can confirm that the C24 does not need a powered microphone.
cheers john
john estcourt
www.amourweddingvideos.co.uk
John Estcourt is offline   Reply With Quote
Old May 16th, 2013, 10:52 PM   #7
Thanks much John!
