-   -   Shotgun mic curiosity (https://www.dvinfo.net/forum/all-things-audio/527010-shotgun-mic-curiosity.html)
Gary A. Smith February 23rd, 2015 09:10 PM
Ive got a shotgun mic that started acting up, sounds like a loose wire. I managed to get it apart before busting something. The short tube with XLR connector has the gnd rivited to the centre of a tube inside that one that then goes up into the long tube that houses the electronics and inserts. The other 2 xlr pins run wires up the outside of this inner tube to the long tube and onto the circuit board. I found thatvthe gnd wire is open circuit between xlr pin and rivet on top of short tube. How would that come adrift? I cant get short tube undone. Any special way? Anyonehad same problem?
Richard Crowley February 23rd, 2015 09:51 PM
Re: Shotgun mic curiosity
It is almost impossible to suggest anything as we have no idea what mic you are talking about, nor do we even have a photo to look at.
We don't know how the XLR pin assembly is secured into the microphone. Some XLR pin assemblies are secured with a screw which goes into a lug where you could "get" the shell/ground connection. But an actual wire is always better, which is likely why they designed it that way.
Anything you can do to give us a better idea of what you are asking about would be very helpful.
Microphone brand? Model number? Photos of the problem?
Gary A. Smith February 24th, 2015 05:47 AM
Sorry, im not usually that vague, ill post pics tomorrow. Its a cheap mic, around 50 bucksbi think but im curious as to whats in the section that has failed.
