Synching timecode to Canon C100 MKii
Can you jam to this camera?
Re: Synching timecode to Canon C100 MKii
Yes, if you record with an Odyssey, Shogun, or Pix.
So your saying you can only sync to an external recorder?
Jammed to what? TC audio recorder? (make/model) Would the TC link stay connected, or pulled and continued on free run? For long takes (concert/play), some kind of gen-lock would still be needed or it would likely drift, just like a non-TC set-up.
Yes jammed to TC audio recorder, probably SD744t. No long takes. It's for an industrial. I would re-jam after each set-up.
You could always use Tentacle Sync
Ambient Nanolockit?
Working from memory here...
Which do you want to be the master clock, the C100 or the 744T? C100 as master? IIRC, the C100 only outputs its TC through the HDMI...not sure offhand how to pull that out so you could feed it to the 744T. And anyway, even if you could get it to work, that'd be a less-than-optimal way to work, I think, since the 744T has such a great and accurate clock and the C100 not so much. 744T as master? Best approach, I think, would be to use the 744T to jam a small timecode box such as a Tentacle Sync, Mozegear TIG, Ambient NanoLockit, or something... and then feed the output into one of the C100's audio inputs.... Does this and everyone else's posts answer your question, or am I missing something? |
The new Sound Devices MixPre-3 and 6 were made for this. HMDI output from C100 MII feeds Mix-Pre that records super high quality audio with TC lock to C100 MKII. Cheap too.
That's a good suggestion.
Seems like it'd work great if you kept the MixPre and C100 cabled. But if you jammed or otherwise disconnected, I wonder if the C100 would hold time through setting changes, etc during the day. Perhaps just rejam with some higher frequency? I don't really know. Could be a great solution, though. Those new MixPres are cool little recorders... |
Not sure if you've seen them in person Jim, I think SD's intention is that they stay with the DSLR mounted and plugged in, not sure what happens with the TC drift or if it is even possible to start and then disconnect HDMI and keep recording? I think the recording in HDMI mode is triggered by the camera so probably not possible to disconnect once recording has started but who knows? My only experience with HDMI recording is the Atomos recorders and they obviously have to stay tethered, being video devices, not sure about these new Sound Devices MixPre recorders. But they are really tiny and light weight so I think intended to stay with the camera they are plugged into?
Ya, I've seen them. As you say, with HDMI connected it should work as planned. But when I see "jammed" I think of someone connecting a cable, syncing TC, and then disconnecting a cable. That may not be universal, so I shouldn't assume that. OTOH, some people freak at having anything attached to their camera, so I wonder if Marco (and others) would be resistant to attaching/cabling one of the new small MixPres to his camera. Not a bad way to go if you can make it work for you...
But with a 744T and a C100, I'd still go for a small TC box pumping into the 3.5mm audio jack of the C100... |
