One mic for 3 camera shoot
Hello, I am planning to shoot with 3 cams. (a GL2 and 2 Optura 60's) running a one mic/boomed to the GL2. It's a one location movie (small house and backyard), 80% indoor scenes(no carpet) and 20% in a outdoor garden patio. Most scenes have 4 characters in close proximity.
My questions are: What is the best one mic (indoor/outdoor) for this situation in the $300-$700 and $1000-$1300 range? Can one mic do it or do I need 2 mics- one for indoor and one for outdoor? With one mic boomed to the GL2 what should I use? Which is the best? A mixer or a pre-amp? What brand/model...Sound Design MixPre, Shure FP-24, Behringer, Mackie, Beachtek DXA-6 or 8? Would appreciate some knowledge, thanks. |
A Schoeps cmc641 ($1400), or an Audio Technica 4053a hypercardioid.
Do you want to feed all of the cameras with sound from the same mic? If you plan on doing this for a while, a Sound Devices 302 is a very good place to start. Ty Ford |
Thanks Ty for the mic info.
Should I feed all the cams with one mic or just one cam, whats the best for post-production? You mentioned the Sound Devices 302 mixer. Are you saying the mixers give you better sound than say a pre-amp (Beachtek DXA-8). |
OK so you then have to sync those cameras up to you main camera audio track. If you had all three cameras aimed at the same thing, you could cut between them more easily if they all had the same good audio. Even two is better than just one. Yes Sound Devices arew better mixers and have better preamps and limiters. At some point you have to move away from bolting something like that to your camera. When the audio device is bolted to the camera, you really can't mix or you'll jar the camera. I'm not certainyou can feed three cameras from a Sound Devices 302. I know I can with the 442. Regards, Ty Ford |
Cool, mixers are the way to go.
Ty, you said a SD442 mixer can go into 3 cams. Since the other SD mixers 302 and the MixPre have 2 XLR outputs also, can they feed 3 cams too? |
I suppose if you feed each camera with only one output. That makes me a little nervous. The MixPre XLR outputs, BTW are line only. The 302 XLR outputs can be adjusted from mic to line.
Regards, Ty Ford |
I'd be concerned that the audio recorded on the Opturas might be noticably different in character from that on the GL2 due to the audio circuit differences in the two camera models. Be prepared to do some equalization etc in post to get them to intercut seamlessly. Still, as Ty pointed out, that's going to be far less headache than if they were recorded using a hodge-podge of your boom mic and their internal mics, all in their own individual acoustic environments at different distances from the talent. Of course, if you're shooting multicam - say the GL2 recording a MS 2-shot of the talent interacting with the Optura's getting the CUs of the individuals at the same time - using just the track from the GL2 or even an independent audio recorder for double system sound all the way, synching up all three pix in post and intercutting between the several camera's video over the one audio track may be best of all. |
Thanks guys, your'e information is great.
Steve, I like the method you suggest - using 2 channels on cam A (GL2) with a 8dB differential on the channels. The way to get 2 channels on the GL2 is to use the Canon MA300 XLR connector, so I could cable L/R outputs from the mixer to the GL2, right? My budget for cams B and C is $1,800, is there any cameras that would do the job of getting better audio and/or picture than the Optura 60's to use with the A-cam GL2? |
Are you purchasing your B & C cams? Why not rent or lease a couple more GL2s rather than tieing up capital investing in 2 secondary cams only to have them sitting idle when you're not doing a multicam shoot? |
Steve, after the shoot, the Optura's would be given to the 2 actors/producers who paid for them. "I won't have no cameras idling in my production house."
Which method would be better for sound and post-poduction; a mixer to GL2 or mixer to GL2 + two Opturas 60's? |
I think I'd focus on getting the highest quality audio on either the GL2 A camera or record to a separate audio recorder. Let the B and C cameras record scratch tracks using their internal mics as refernces to aid sync'ing to the production audio and use a clapboard slate at both the head and tail of every shot. |
Nice filmmaking breakdown.
I will go with the 'mixer to one camera' set-up, it has many positives for my film project. To use 2 channels, one for insurance as you suggested on the GL2 camera A, can I use a MixPre with the two L/R outputs and XLR cable it to a Canon MA300 XLR connector? Or what? Are the MA300 2 channel inputs and the MixPre L/R outputs both line? |
Do you mean like a piece of cotton?... just joking, would padding be a special cable or device? Or is their a mixer with the price range of a MixPre that has mic/line switchable outputs? Thank you Steve.
