Amateur audio questions
Hey guys. I am new to the "audio" part of videoing. I am about to purchase a Sony VX2100, and would like to upgrade to better audio. I know you need to spend quite a bit for good audio, but I do want to start out cheap and I can upgrade as I go. I have the Sony ECM-MS908C stereo mic that I've been using with my TRV18 Sony cam, and I do like it. For starters, I'll use that on the VX2100 and would like to add a wireless mic. Now I do know a lot of mics are mono. Is there a reason for that? I am not sure why someone would use mono. Also, with the Beachtek adaptor, can I adjust the volumes separatley with 2 mics, or do I need a small mixer for this? Thanks for any replies.
Hey thanks Steve. I never thought of the post idea of moving the sound where you need it. Duh!
Try to avoid adjusting the volume controls on the adapter while recording as this may introduce contact noise from turning the potentiometers - instead, set the levels prior to recording. |
Also, adding to Bob's comments, having the camera operator also "ride gain" on the sound keeps you busier than a one-armed paperhanger. Use the Beach at the camera end to couple an XLR feed from mic end of the line to the miniplug the camera wants and in conjunction with the camera's own attentuator and level controls to set the master recording levels. But at the microphone end of the line feed the mic into a mixer such as an SD MixPre and have the boom operator or sound mixer monitor the sound and control the levels there during the take. You set the camera to manual control and set the recording level controls to about 2/3 full-up. One of the things to look for when you get your mixer is a built-in reference tone - if you'rs doesn't have one you can get a plug-on tone generator that plugs into the mixer input port for not too much money. You send tone at a 0db reference level according to meter on the mixer down to the Beach and set Beachy's level controls so the meters in the camera show you're recording the tone at -12dbfs. Now a 0db indication on the mixer indicates the audio is getting into the camera at the optimal recording level. The boom operator or sound mixer has the mixer at his end of the line and controls the mic position and levels to keep the signal at bouncing around 0db on his meter. |
