Irivers questions
I read a lot on the Irivers. Sounds promising in capturing "speech". I want to know if I need to do anything else as far as post production. Can the sound captured be plugged onto directly onto NLE time line or do I have to do "touch ups" on another audio program to get the capture sound good.
Second question, can somone give me an idea how much audio a 256mb can hold? Thanks |
I have an iRiver 790T with a Giant Squid lav mic (there is a special one that Giant Squid makes for the iRiver because the iRiver is wired backward for mono). The sound is good considering it’s recording in MP3. There is a slight noise floor but I use Sound Soap 2 in post to remove it. (I use Sony Vegas NLE so I can do this right on the timeline)
Considering the price it’s a decent setup. You can get 3.5 hrs of 160kbps mono recording on 256MB memory. ~jr |
Fred,
Here is a recording time chart I put together on another forum: Expected record times based on 512 Mb model (256 will be half...1Gb will be double the record time below) In mono: 44hz 32kbps = 35 hours: 31 minutes " " 40kbps = 28 Hours: 25 minutes " "" 48kbps = 23 hours: 21 minutes " " 56kbps = 20 hours: 18 minutes " " 64kbps = 17 hours: 45 minutes " " 80kbps = 14 hours: 12 minutes " " 96kbps = 11 hours: 50 minutes " " 112kbps = 10 hours: 09 minutes " " 128kbps = 8 hours: 52 minutes " " 160kbps = 7 hours: 06 minutes In Stereo: 44hz 64kbps = 17 hours: 45 minutes " " 80kbps = 14 Hours: 12 minutes " "" 96kbps = 11 hours: 50 minutes " " 112kbps = 10 hours: 09 minutes " " 128kbps = 8 hours: 52 minutes " " 160kbps = 7 hours: 06 minutes " " 192kbps = 5 hours: 55 minutes " " 224kbps = 5 hours: 05 minutes " " 256kbps = 4 hours: 26 minutes " " 320kbps = 3 hours: 33 minutes |
Thanks Mark!
In the same vein, I have an Irivier H10, which doesn't have the same features as the older 120 for recording. Does anyone here have experience with it? I have the 20gig HD version. Beachtek has come out with a DXA-10 designed for stereo recording to consumer based devices. Seems like that would be great if the quality made it into the Iriver. |
