Cheap Solution for Boom
What do you all think of this for a cheap hi quality boom solution?
http://www.bhphotovideo.com/bnh/cont...goryNavigation Rather than relying on the camera mic, and not spending many hundreds on a shotgun mic, pole, and battery solution, I thought a digital recorder strategically placed to pick up dialog would be good. Any thoughts or suggestion? Uses: Dialog for indie flicks. |
Where would you place it? To get good dialog a mic has to be close to the source. Planting it on the set many feet away from the talent will be too far and slipping it in a pocket would muffle it.
Input
1 x 1/8" Stereo Mini, Microphone 1 x 1/8" Stereo Mini, Line 1 x 1/8" Stereo Mini, Line(Optical) 1 x USB I/O Port I'd be most worried about the sound quality it is supposed to record...and at that price point, you could start looking at some Flash RAM/Hard Disk recorders: http://www.markertek.com/SearchProdu...f=60&sort=prod http://www.markertek.com/SearchProdu...f=97&sort=prod http://www.markertek.com/SearchProdu...f=96&sort=prod as for the shotgun + boom pole, you can get a decent shotgun for $50 - $100 and can make a boom pole for less than $20 at home depot. |
I'm with Cole on this one. My set up is a Sony MD recorder plugged into the right mic for the situation. The boom pole is an extendable aluminum broom pole. I took a roll of plumber's strap (bendable metal strips with holes in them) Made two big circles and ran rubber bands through the holes for noiseless support. There is an opaque plastic squeegee attachment for the broom pole, I just removed the squeegee part and kept the screw on mount, ran two screws through it and tightened. Works like a charm.
http://webpages.charter.net/knightscape/blimp/
Some images of the mic setup I've got...I've switched out the mic stand as a boom pole with a 12' extendable aluminum painters pole with a 3/8" flare male to 1/2" Pipe Female brass adaptor which puts the paint pole on thread with standard mic holders. The blimp is comprised of gutter screen cover (for keeping leaves out of the roof gutters) cut to length and wired together into a tube, chopsticks and rubberbands as a shock mount and an old mic holder wired into place. Cover with costume fur sock and you're good to go. |
Maybe I misinterpreted his post but I thought Marco was talking about using JUST the MD recorder with its internal mic so he would not have to invest in boom poles, additional mics, etc. While putting the recorder in the talent's pocket with a decent lav attached could work well, as could a mic on a boom of some sort feeding to the recorder being carried by the boom operator or fastend to the boom, that's still adding more stuff over and above the naked recorder which is what I thought he was asking about using.
Yeah a friend of mine has two of those MD recorders and just clips the mic to the inside of a collar or somewhere not super visible. I also don't have the bloke to hold the boom pole, so it's easier to have something stationary, I think. is 44PCM not good enough quality?
I thought he was asking that as well although based on cost savings, hence the low-budget options. I could be wrong.
I have thought about using a low budget boom setup, but I usually don't have enough people at most shoots to hold the pole. I am trying to minimize labor. I also thought about mounting the boom somehow, but it seems like a lot of trouble when I could just place a recorder in a pocket and clip a small stereo mic to a sleeve or collar. $300 is pushing my budget.
