Another audio question: Tascam HD-P2 or Marantz PD671
To the audio experts_
Definitely I will buy a digital field recorder....so I have -for the same price- two options:Tascam HD-P2 or Marantz PD671....What to do? Are they similars? Which one has more advantages? Regards FP |
Go Tascam or go home - you will get fired and go home if you get the mirantz - J/k both are good but the Tascam is much better.
:-) Tascam....thks
Other than timecode, why the Tascam?
The biggest drawback of Marantz gear is notoriously bad pre-amps. They (those at the company) even pretty much admit that you don't want to use anything other than a condenser mic, due to high levels of hiss when using dynamic mics. It's a common complaint of their stuff in general.
The marantz also cannot be firmware upgraded by the user. However, the Tascam cannot do XLR line In, regardless of what the manual or the printed "Line In" on the casing said.
A friend who is a recording artist and an excellent recording engineer has worked with the Tascam P2 and had nothing but good things to say about it.
Wonderful performance, absolutely silent operation. It does have two channel XLR in with phantom power. That's what he was using for some field recording sessions recentlly. |
