Can I Get Good Audio Without XLR Mic-in Socket?
Hello,
I'm doing research on which camera I should buy for short movies and interview shows I'd like to produce. I've decided to go for the less expensive 3CCD cameras like the Sony DCR-TRV950 or Panasonic PV-GS300 for good video quality, but I'm also concerned about audio quality. The microphone inputs on these cameras support 3mm jack plugs instead of balanced XLR inputs. What would the noise level be like if I use a microphone that has this jack plug or a mixer whose output is connected to the camera through this plug? Can I get good audio without balanced XLR mic input? Thanks. |
The beauty of XLR socketry is the roobustness, the ability to choose from a vast array of mics, the phantom powering and the fact that long hard-wired leads won't cause you a problem.
For short runs a mini-jac mic will give you just as good results, and firms like Rode and Senheisser make the same mic in both configurations. tom. |
Not having XLR's on the camera doesn't mean you are stuck, though. Beachtek and Sign Video, among others I'm sure, make XLR to mini conversion boxes that let you use XLR balanced mics with a camera that only has a mini input and several of them also provide phantom power for mics that require it. |
One other disadvantage (at least for some people) of the 3mm system is that you can typically only use one microphone at a time.
The XLR adaptors will give you connections for two mics, as well as most (all?) camcorders with xlr inputs. |
I think Seth made a good point that an external adapter like a Beachtek is the best method for inputing to a mini-plug. It gives you xlr options plus much more control over the signal. Also does line inputs for pulling a feed or a running a hot mic.
Ben |
Thanks a million for the information.
