Giant Squid - mono or stereo
So, i now have obtained the illusive iRivers, got my hands on two 895s (seems they were the only two left in the known universe, well the internet anyway!). I have numbered my questions as reading it, looks too mixed.
1. I see from searching the forums that a good pairing is the giant squid but i am unsure as which one to go for. I see there is a mono version specifically for the iRiver 700/800 series but not sure if I should go for mono or stereo. 2. I also have not managed to locate a UK dealer or website that I can purchase them from. I will buy direct from US if required but would be great if there was a europe outlet. 3. Also, I looked at a list of recording times in mono and stereo against Storage Rate (Kbps) and wondered what the acceptable lower limit was for recording or if the lower limit was indeed the highest setting... Any help/comments greatly appreciated as I need to get them as soon as for next wedding on 17th Feb. |
My feeling is that the notion of a stereo lav is an oxymoron. Stereo implies a mic setup with a fixed orientation and you're not going to have that with a mic on someone's clothing. There might be some use for stereo when you're using them as a concealed plant mic but since you're picking up dialog, the norm is to record that in mono anyway. Go with the mono mic.
Thanks for the rapid response!
The iriver quirk (taken from http://www.giant-squid-audio-lab.com/gs/gs-mono1.htm):
I agree with Steve, the mono GS lav. is best, and the omni sounds better than the cardioid. I've got some of each of all the GS mics. The stereo is actually 2 mono mics, each on short cables into the one box.
I think you should also get their 9V battery box. Sounds better when you add a 15' extension lead to the lav. |
As mentioned when used clipped on a person to record his voice you would want a single mono mic, if it was a Giant Squid better the omni.
Since you have 2 irivers, if you get 2 mono mics you can easily combine the two to try out stereo configurations e.g. 'spaced omnis' to record music or ambience. Forthat you need to build yourself an adapter so that one records to the left, the other to the right channel ( I have done that for my 2 Giant Squid omnis ) You won't find an outlet in Europe and there also is no need for one: Shippping from the US when ordering directly from Giant Squid is 5 USD only, and often there is a special offer for each mic for 25 USD instead of 30 UDS. |
Get the right angled connectors for the 895, since the mic input is on the side. Quote:
