Rode VideoMic question
For anyone that uses the VideoMic, do you find that you need to use pre-amplification on it such as a Bluetube for shooting dialogue from about 10 feet away (indoors)?
There would be several problems using the Bluetube in any case, Blue is AC powered, hard to use on location. Blue is stereo, Videomic is mono. Blue has XLR inputs, mic has 1/8 connector. There's another problem you're going to encounter evidenced in your post that you need to worry about far more than a choice of preamplifier and that's trying to shoot with the mic 10 feet away from the talent. That's way, WAY too far away for good dialog recording. Even shotgun mics like the Videomic are intended to be used much closer, optimally 24" to 48" away from the source. If your heart is set on spending the couple of hundred bucks the Bluetube costs, you'll get far more benefit for your buck buying a boom pole, shockmount, and extension cables to get that mic up close to the talent where it's supposed to be. It ain't as glamorous as a spiffy tube preamplifier but it's far more important when it comes to getting good sound. |
improvising with the videomic
Rode makes a 10' mini female -> mini male extender cable for the video mic by the way so you can get it closer by boom poling it or putting it on a tripod close to the subject, rode makes poles and minitripods with connectors to fit the videomic's base too.
You can also mount the mic on a litte consumer camera and put that camera on a monopod to "make" a boompole Or you can put the extra camera on a mini-tripod, tripod or monopod to "make" a mic stand for it. Shayne Weyker http://weykervideo.com |
Cheers. |
You do have to take off the shoe-mount part on the bottom first though to do that because it blocks the hole.
It's easier to use a 3/8" -> 1/4" adapter fit into the 3/8" threaded hole. Then you don't need to move anything on the mount.
No mic is designed to be used for dialog indoors from 10 feet. Indoor dialog requires lavs or a hypercardioid. Regards, Ty Ford |
LOL!
That's a serious interference tube! |
Ty Ford |
