3 Mega Pixel MPEG-4 and JPEG Motion Streaming Color Camera
1 Attachment(s)
just wondered if anyone had thoughts on this camera as a 720P CAPTURE WITH A LAPTOP...
GVI Security SNC-M300 3 Mega Pixel MPEG-4 and JPEG Motion Streaming Color Camera at Markertek.com The SNC-M300 is a high resolution color network camera that comes equipped with a 3 mega pixel CMOS chip that is capable of progressive QXGA (Quad eExtended Graphics Array) scanning. The camera has a maximum resolution of 2048 x 1536 and comes equipped with a SD card slot for on-alarm event recording retrievable over the network. Dual Coding & Dual Streaming With dual-encoding capability, the GV-SNC-M300 can generate and transfer both MJPEG and MPEG4 images simultaneously (PAL 25fps). This dual encoding and streaming capability is useful for transferring MPEG4 images over limited network bandwidth, while also storing high resolution MJPEG Images to the Nertwork Recording Software or NVR device. The SNC-M300 uses an onboard embedded Linux OS with standard network protocols such as TCP, UDP and FTP among others. The SNC-M300 streams its video output in TCP and UDP (Unicast and Multicast) with MPEG4, MJPEG and G.711 compression. The camera connects to the network by way of a 10/100 Base-T Ethernet connection. The video quality from the camera is available at Very High, High, Normal, Low, and Very Low settings. It supports SAMSUNG DDNS and public DDNS servers. Images are viewable by way of a web browser (IE 6.0 or higher), or with Samsung's Net-i software. The SNC-M300 has built-in motion detection that can be set at high, medium and low sensitivity. On an alarm event the camera can be set to send an image by FTP, e-mail and record. The SNC-M300 defends your network integrity by coming equipped with three access levels, administrator, operator and user. The camera supports two way audio and has various time settings, such as NTP Time Sync, Time Zone, and Daylight Savings time setup. SD Memory Card User can select important images to be recorded to the SD memory card such as: Alarm Events, Motion Detection or Time Scheduled Events. Using the WebViewer or asd;lkjkkkksoftware, you can remotely access the images from the SD card installed in the SNC-M300. It is compatible with SD and SDHC standard and can support up to 16GB capacity of SDHC memory. Features 1/2 Inch 3 Mega Pixel Micron CMOS 1.3M / 2M / 3M Pixel HD/Full HD resolution Dual Codec providing simultaneous MPEG4 & MJPEG Local storage like 1CH DVR SD/SDHC memory slot for local storage Built-in Motion Detection Pre & Post Alarm Image Buffer 2 Alarm Inputs and 2 Alarm Outputs DC12V / AC24V / PoE DDNS Support Power Over Ethernet (PoE) Support Bi-Directional Audio Support C/CS 1/2 Inch Lens Mount Specifications Camera Scanning System: Progressive QXGA Image Device 3 Mega Pixel CMOS Size 1/2" Resolution 2048 x 1536, 1600 x 1200, 1280 x 1024 MJPEG / 640 x 480 MPEG Minimum Scene Illumination: 2 Lux Dynamic Range: 50db Lens: 1/2" CS/C (Adaptor) Manual Iris (not included) OS Environment Network Board OS Embedded Linux Client Viewer OS Windows XP, VISTA Client S/W 1Ch Web Browser Viewer (Default), NET-I CMS S/W (Ver.2.5) Web browser: Internet Explorer 6.0 higher Compression: MPEG4 , MJPEG, G.711 Audio & Video Codec Network Hardware Flash memory 16MB; SDRAM 128M byte Ethernet 10/100BASE-T Network Protocol TCP, UDP, NTP, HTTP, DHCP, PPPoE Streaming: TCP, UDP (Unicast, Multicast) DDNS Supports Samsung DDNS and Public DDNS servers Resolution 3 Mega 2048 x 1536 2 Mega 1600 x 1200 1.3 Mega 1280 x 1024 VGA (MPEG) 640 x 480 Frame Rate: 25, 19, 13, 12, 10, 6, 3, 1 ips Video Quality: Very High, High, Normal, Low, Very Low Motion Detection Sensitivity: High, Medium, Low Audio: ADPCM, G.711 2-Way Connection Users: Max 10 Users at Unicast Mode Alarm Event Input: Image transfer FTP, E-mail Notification Motion Detection: Image transfer: FTP, E-mail Notification Schedule: Image Transfer: FTP, E-Mail / Recording: SD Card IP Installer IP Address Setup Assistant IP Installation function; (XP, Vista support): Auto detects Software Upgrade: Firmware upgrade by web browser Access Level Login Access Level Administrator, Operator, User Time Setting NTP Time Sync, Time Zone, Day light Saving Setup Language: Multiple Language GUI Support SDK HTTP API CGI Commands: Provides functionality to control cameras and set/retrieve internal parameter values Windows API Windows API for viewing data streams from network camera I/O Sockets: Power (2-Pin Term), RJ-45, SD Card Slot, Terminal 6Pin( Alarm In 2Pin, Alarm Out 2Pin, GND) Environmental Conditions: Operating Temperature 14§ ~ 122§ F (-10§ ~ 50§ C) Humidity 20% ~ 85% RH Power Requirement AC24V (60/50Hz) / DC12V / PoE LED Indicator: 3ea Physical Specification Dimensions (WxHxD) 3.26 x 2.39 x 5.78 in Weight 0.93 lb Body Color: Silver |
You'd probably be interested in the Elphel project. We are filming 1920 x 1080 pixels (from a 5mpixel chip) to an onboard hard disk right now.
It's an ever continuing project because the founder of Elphel, Andrey Filippov, is devoted to 'open source' and 'open' projects. Take a look at our thread. |
great
that sounds great and I'll look again at the thread BUT that didn't give me any thoughts on this camera... Thanks for the reply...
It looks like an interesting device, here are a few thoughts:
What is Video Quality: Very High? Frame Rate: 25, 19, 13, 12, 10, 6, 3, Why not 24? Resolution: 3 Mega 2048 x 1536 Ok so it's a 4:3 Sensor, but can it also do 16:9 windowing? There is very little info about how the internal camera parameters like exposure time, white balance, etc are handled. As Oscar mentioned, this camera is not as powerful as an Elphel at around the same price level. |
perfect
just what I needed to know... thanks so much...
| All times are GMT -6. The time now is 01:07 AM. |
