35mm lens adpators for 2/3" cameras w/o flip image
Hi,
More and more 2/3" cameras (HDW-900R, HDX-500, PDW-800,...) now come with a built-in digital image flip feature which I assume should make 35mm lens adaptor rigs simpler, lighter and less expensive. Is anyone offering 35mm lens adaptors with B4 mounts (for 2/3" camera) and without a bulky optical image flip module? Thanks, Thierry. |
Dont forget the JVC GY-HD200U/250
They both have image flip also. |
Thierry,
Letus and Cinevate have developed b4 relays for 2/3 chip cameras. I read somewhere in this forum or the other that they might work for adapters without the integrated flip. Also, brevis is a modular adapter, so I think you can use the relay straight to the brevis without the flip module. Subject to the maufacturer's confirmation, or from someone's experience I think you may be able to use letus or cinevate relay's on the g35, the sgpro or redrock sans flip. Hope that helps. Ted P.S. I too use the jvchd200 + adapter w/o flip as mentioned by Cameron but these are 1/3 inch sensor cams. |
That's correct. The Brevis can be used in non-flip mode on these cameras. For most, our 72mm spacer is required between the unit and our 72mm non-flip achromat.
Cheers, Dennis Wood www.cinevate.com |
1 Attachment(s)
This is a straight set up with Varicam and Brevis with my relay
| All times are GMT -6. The time now is 10:25 AM. |
