Lens center to rods standard distance in 15mm rod systems?
Is there any information regarding lens center to rods center vertical distance?
I mean lens height from rods center in 15mm rod systems like Cavision`s... I know that Cavision rod systems for example are 60mm from rod center to rod center but I don`t know what is the designed lens center to rod center distance. Or shouldn`t I worry about that as most FF systems are that much adjustable? Thanks in advance, t. |
60mm to centres, 85mm to optical axis.
some of cavision's matteboxes are actually adjustable in height with the help of a bracket, and some follow focus tools, like dan's, dont care what height you set the lens at.
it's the higher end stuff you need to worry about. i.e. chrosziel, century, arri... |
