Matching 35mm adapter & stock lens footage
What are some of the ways people out there go about matching footage shot using the Letus (or other adapter) & footage shot using a stock lens?
John Benton in an earlier post mentioned a technique that helped him: 'Color gain has to be pumped for the Adapter when matching footage with the stock lens... The inverse is also true: match the stock lense by turning the Gain up to 3 and the sharpness down.' Does anybody else have any techniques they like to use? H. |
Henry,
depending on what camera you have, a wide angle adapter (or in my case an SD 3x wide angle XL lens) does 2 things that I find helpful: 1) it allows me to match the Letus & Stock better, while still looking completely HD 2) It allows me to get a good wide shot that often alludes me using a 20mm/24mm/28mm and any 35mm adapter. hope that's useful, J |
Thanks John, I'll have to try that.
H. |
Indeed. When the angle is so wide the DOF is so insignificant you might as well use a filter lens straight on the camera.
