Letus35A flip vs the others
I'm very confused.
There are 2 issues that concerns me more: grain and focus. I need an adapter that lets no glass grain in and that can really focus on things. Almost all the footage i see out there is trash. There is no focus. Everything is out of focus. So is it possible to know if there is an adapter that is able to focus almost perfectly? Is the Letus35 the answer? Thanks |
hi
i Owen the letus35 Fe and let me say its a great toll i had no problems with focus and grain is minimum( i like the look of it) most of what you see is on low compression so its hard to say let me say that for me working with it and the z-1 was great the director will never work without it!!! the videos are broadcast on the music Chanel and look great to!!!! i work with canon FD lenses |
What i really don't understand is why is the grain visible if the glass is moving....
adapters
As a new owner of a Letus 35 and with friends who own other adapters, and having gone through the research process, here is my opinion. You're asking too much from what is already a "workaround" or "modification". These adapters are basically "homemade" - especially the Letus. Quyen - one guy - makes them at his home (as far as I can tell).
You are screwing a tube in front of a prosumer camera that already has "just good" glass (compared to pro Fujinon lenses, etc. - price those out for fun). Then, you are screwing on 35mm SLR lenses, probably used. In the middle is groundglass, on to which the image is projected. Do we not expect some light loss? Some softening? Some grain? What my friends and I who use these realized, is that an adapter gives "a look". And you either like that "look" and want that "look" or you don't. IMO, video is too sharp - too clear. I like the adapter look. In fact, I love it! What you really want, sounds like, is to shoot with a Panavision 35mm camera. Or a Varicam or a Cinealta. You can rent all those things (for a hefty sum). Or you can buy a Letus for $350, screw it in front of a DVX and run around all day having fun. If you want a perfect, super sharp, grain free picture with controllable DOF - that's easy. You just need lots of money. So much footage is posted (see dvxuser.com). You can see all the different adapters (the Brevis is very good). But what I came to realize is the only way to really understand what these adapters are all about is to get one. If you're serious about video, a $350-$1000 investment shouldn't be a risk. You can always sell it as there is a huge market. I recommend you buy and try. p.s. The Letus took a month of "fixing" before it worked right and dust free. See many threads about that here and on dvxuser.com. But, I am happy with it now. See some stills here: http://www.flickr.com/gp/65712140@N00/S23LOZ |
That is pretty fantastic ! Even on the M2 I seem often to be able to see the Ground Glass on stills that people post. I haven't tried the Brevis, but Quyen has made a briliant product ! (and the image can Flip) |
Diffused grain or soft freckles in the image can be attributed to a groundglass in some circumstances where shutter speeds are unrealistically fast or the design employs a small movement.
When operating groundglass devices which use a small movement, the groundglass "grain" may become apparent as a soft, fixed pattern blemish, sometimes described as a "film of grain" which is seen in brightly lit out-of-focus areas or plain bright areas like sky or painted walls during camera moves. If you enlarge the image on a frame grab you may find each "soft" grain occupies an area of 16 to 64 pixels or thereabouts. Moving grain which is relatively sharp and defined and presents itself in all soft areas, light or dark, is more likely to be electronic noise from the camera imager and system. This "sharp" grain will occupy pixel areas of between 4 and 16. It is something which is always there, normally hidden in the small detail and texture of an image shot direct-to-camera where the image remains relatively sharp across the whole focal range. It becomes more apparent when you up the gain in low light conditions. With adaptors, you are seeing more and much larger soft out-of-focus areas in the image for the first time. Any electronic noise in the image will no longer be concealed in the detail. Shoot an image containing high contrasts and large uniformly out of focus areas with the groundglass motor turned off. Study the soft areas closely and you may well see some moving grain in there. Now how can that be with the groundglass not moving? I can't vouch for my observations as being scientifically pure as artifacts might get into the mix through added steps in the frame grabbing and move to another still-image software. |
As i'm not good at hand works, could i damage it trying to clean it? And finally why paying 700$ for a lens that isn't useable unless you disassemble, clean and reassemble in a humidity and dust free environment? |
There are many adapters out there that people use regularly with GREAT results. I don't know another way to get DOF control at this price point, so you either have to get some cash and dive in, or else fuggedaboutit. I dove in, and although it isn't magic or instant or perfect (what is in filmmaking - no one is every satisfied with the 'quality' of their rig it seems), you can make it work if you're careful and lucky. Or again, you can always just spend a lot of money and skip the luck part. : ) Here are some stills from the last shoot with the Letus35a and a DVX100, black dust speck and all. If you want to play "Where's Waldo?", the black speck is in the upper right corner. Visible on shots where the background is lit and flat. http://www.flickr.com/gp/65712140@N00/4z2vo5 |
So my question: for $1500 what adapter would you recommend for best quality, best focus, cleanest image?
