| Attend the World Premiere All about the world of Adobe Premiere and its associated plug-ins. |
How to copy L channel to R in CS3?
I recently went from premiere CS2 to CS3.
In CS2 with a simple copy and a couple of check boxes I could double the Left Channel to the Right Channel, or vice versa. However, in CS3, I can't figure out how to do it. (And is well known, I can't do it by opening the audio in SoundBooth, and I can't directly open the audio in Audition.) Is there an easy way in CS3 to copy the Left Channel over onto the Right Channel? (The mic was recorded on the left channel and nothing was recorded on the right. |
There should be a "Fill Right" effect in the Audio effects that duplicates the left channel data to fill the right channel.
Or you could have it treat the stereo file as dual mono tracks (in the audio options), and pan the left mono track to the center in a stereo sequence.
For more information on these topics, check out my tech website at www.hd4pc.com |
Thank you! I found it!
