Are these keyboard shortcuts available? at DVinfo.net
Adobe Creative Suite
Old July 29th, 2009, 07:13 PM   #1
1. With keyboard shortcuts you can bring a clip from the Project Panel to the Source Monitor, than to the Timeline. However, is it possible to bring a clip from the Project Panel, directly to the timeline?
2. When in the Timeline panel, is it possible to select a clip? Often, I'm doing my JKL editing, or cutting with Ctrl + K, and I'd like to select a clip but it seems I must use the a mouse.
Joe Riggs is offline   Reply With Quote
Old July 29th, 2009, 08:03 PM   #2
No and don't think so.
PP is very mouse driven which is a major time sink for me, but it's always been that way and I've been using it going back to Premier 1.x. Odd when compared to AE where keystrokes can do almost everything up to stopping the Earth's rotation.
Old July 30th, 2009, 02:20 AM   #3
Originally Posted by Joe Riggs View Post
...However, is it possible to bring a clip from the Project Panel, directly to the timeline?
Yes, select the clip and choose either , (comma) or . (period).
, = Insert Edit
. = Overlay edit
No, one cannot select any clip wih the keyboard.
/Roger
/Roger
Roger Averdahl is offline   Reply With Quote
Old July 30th, 2009, 06:22 AM   #4
, = Insert Edit
. = Overlay edit
You can do that from the project panel? I'll have to try that today. I thought you could only do that from the clip window.
Old July 30th, 2009, 08:27 AM   #5
Yes, otherwise i would not have wrote it. :)
You wrote that Premiere Pro is mouse driven which is a major time sink for you. There are tons of unmapped commands that you can map to keyboard shortcuts. Go to Edit > Keyboard Customization and enjoy.
If you want them all on a paper, to easier see the ones you want/need, hold down Ctrl+Shift and while holding them down, go to Edit > Keyboard Customization and look for the >>Clipboard button. When you click on this button you copy all of the aviable keyboard customizable commands to the Clipboard, so you can paste it into any text document and print it out to discover everything.
I use the keyboard for almost anything in Premiere Pro, rough cuts and fine tunings of clips on the Timeline. There is very seldom (never) need for the Ctrl+K to remove clips or part of the clips from the Timeline. In Points, Out Points and an Extract Edit/Lift Edit takes care of that, without the need to touch the mouse. So i have an opposite experience, there are a lot of things you actually can do without the mouse in Premiere Pro. :)
/Roger
