MainConcept MPEG HD plugin for Premiere Pro at DVinfo.net
Adobe Creative Suite
Old April 22nd, 2004, 05:13 PM   #1
http://www.mainconcept.com/mpeg_pro.shtml
Haven't tested it myself but they promise an ability to capture straight from HD10 and edit MPEG natively on Premiere Pro.
-ztn
Sten Newfield is offline   Reply With Quote
Old April 26th, 2004, 12:44 AM   #2
Well, as expected, the speeds were nowhere near the DV speeds, but still in the ok-land. I imported 2 .ts files just for a quick test, slapped a few transitions and a color correction upon the clips and was able to scrub back and forth with 0,5 - 1 sec delay. This was on 2,4GHz HT P4 with 1GB of memory, MainConcept recommends 3GHz.
-ztn
Old April 26th, 2004, 03:16 PM   #3
I've been using this plug-in in demo mode for about a week and I must say that I am impressed, it sped up my performance quite a bit. It also fixed the lockup problems that I was having when editing in Premiere Pro before I installed the plug-in. (This might be because of a bad codec or filter I was never able to find)
It seems about as fast as editing standard DV on my last PC, a 1.8ghz p4.
(New PC is a 2.8ghz p4 HT, also has faster hard drive)
Editing 720p in Premiere Pro is as easy and stable as editing and capturing regular DV, It allows for real-time capture preview as well as function controls for Play, Rewind, Stop, Pause, Ect... I defiantly prefer this plug-in to a separate program for capturing.
All in all, I like it very much. Anyone want to buy me the full version?
Jeremy
4volt.com
Jeremy Peterson is offline   Reply With Quote
Old April 26th, 2004, 03:17 PM   #4
I forgot to mention, it also supports SD mode as well :)
Jeremy
4volt.com
Old April 26th, 2004, 07:05 PM   #5
Would it be possible to export the timeline as m2t file and then send back to hd10?
Procoder 2.0 is a new release. It seeems that Procoder 2.0 could create m2t file.
Peter Robert is offline   Reply With Quote
Old April 26th, 2004, 07:58 PM   #6
If you use 18300 CBR with 448 buffer size than the mpeg is accepted by JVC LE editor that comes with a camcorder. Transcode it to m2t format - very fast - mainly copy only, exept headers, an you are done.
Andre
Andre
Andre Jesmanowicz is offline   Reply With Quote
Old April 26th, 2004, 08:24 PM   #7
Hi Andre,
Are you saying that encode the timeline by 18300 CBR as mpeg2 file adn then import in JVC LE editor which could output as m2t file?
Old April 27th, 2004, 06:40 PM   #8
Yes,
and the transfer is very fast. No transcoding!
Don't forget to set mpeg2 quality to "High 1440" or you will not be able to use 18300 bit rate. Set I frames to 6 to get BBIBBP GOP, VBV Buffer size to 448 and audio to 384.
Good luck,
Andre
Old April 27th, 2004, 08:34 PM   #9
How does this plug-in compare to the much more expensive CineForm Aspect HD?
Alex Raskin is offline   Reply With Quote
Old April 28th, 2004, 09:08 AM   #10
In AspectHD you are not editing in mpeg2.
Ken
Damnit Jim, I'm a film maker not a sysytems tech.
Ken Hodson is offline   Reply With Quote
Old April 28th, 2004, 09:49 AM   #11
CTO, CineForm Inc.
How does this plug-in compare to ... Aspect HD?
True Aspect HD is not editing MPEG2, but it is doing this for greatly increased performance, and editing freedoms through file compatibility. There is no real-time performance in a MPEG2 editor, yet Aspect HD can mix up to four video streams without dropping a frame on the minimum PC needed to run the MainConcept software. Aspect HD also converts MPEG2TS files into standard AVIs (in real-time) during capture, which allows your HD10U footage to be edited in any PC package including VirtualDub, Vegas, Affect Effect, Combustion etc.
Cost is no-longer a factor if you need Premiere.
Non RT solution:
Main Concept MPEG $349
Premiere Pro $699
Total = $1048
Real-Time solution
CineForm Aspect HD ($1199)
Including Premiere Pro ($699)
Including Audition ($299)
Including Encore DVD ($549)
Now Total = $1199
For $149 extra you get real-time editing plus DVD authoring and audio sweeting.
*** Advertising mode off ***
Aspect HD and the MainConcept solution are very different methods to solving the editing of HDV. Aspect HD is targeted to particular professional needs, just us next product, Prospect HD is for even higher-end HD editing. We expected the MainConcept and Ulead products, so we created the Connect HD product to complete. Connect HD is much more feature compatible with the MPEG editors. All those products are under $500 and offer the cost sensitive purchaser (aren't we all :) ) plenty of choice.
