Media Encoder taking forever. at DVinfo.net
Adobe Creative Suite
Old September 28th, 2009, 05:00 PM   #1
Media encoder is taking about 20 mins on average to begin rendering a file. No matter what the project, sometimes longer. Just says loading and takes forever to start. ofcourse It also fails a lot.
Getting this message when i click for more info after a fail:
Could not read from the source. Please check if it has moved or been deleted.
I opened the same project on another computer ( a slower laptop) and it started rendering almost imediatly. So something must be wrong.
Tyson X
Tyson Persall is offline   Reply With Quote
Old September 28th, 2009, 05:12 PM   #2
Your profile says Vista64 and CS3. Unless Adobe has done a recent CS3 update, it isn't certified to run on that OS. Some people do it successfully; others have problems. I guess we'll see if anyone has run into this and solved it...
Pete Bauer
Old September 28th, 2009, 09:00 PM   #3
This is a common warning message in CS4, for the following reason: Error: "Encoding Failed. Could not read from the source" (Adobe Media Encoder CS4 on Windows)
I know you are on CS3, but perhaps this is a clue to some similar issue?
By the way CS3 works GREAT on my Win7RC 64-bit system, so keep that in mind if Vista64 doesnt work out for you.
Old September 29th, 2009, 06:10 AM   #4
No, Im talking about CS4 . And im thinking i need to do a full reformat of my hard disk to fix this. CS4 was working flawlessly before for about 3 months on my current system. THen after some update, things went not so smoothly any more and i cant get it back. Not ghosting, nor system restore can get the errors in premiere and Media encoder to correct back to the way they were.
Tyson X
Old September 29th, 2009, 07:16 AM   #5
Did you "turn off" the video preview in the AME? It slows things down.
Todd Clark is offline   Reply
