Encore CS3 compatibility with Windows 7 at DVinfo.net
Adobe Creative Suite
Old November 10th, 2009, 05:04 PM   #1
Windows 7 upgrade advisor says of Encore CS3 there may be issues running this programme under Win 7 and recommends uninstalling the programme before installing Win 7.
Does anyone have expererience of this issue?
Is it possible to get Encore CS3 working with Win 7, or do I need to upgrade to Encore CS4?
Steve Pesenti is offline   Reply With Quote
Old November 10th, 2009, 10:45 PM   #2
Just upgraded from Vista 64 to win 7 64. I tried the upgrade path but it just hangs up in the middle of installation, waited for 3 hours and nothing happens, so I just re-installed from scratch and takes only 30 min. with i7 920 system.
Jun
Sony Z7U, Canon 5D Mark II, Canon 24-105 F4L, Canon 70-200 F2.8L, Canon 580 EXII, Zoom H2.
Jun Galinato is offline   Reply With Quote
Old November 11th, 2009, 03:48 AM   #3
I upgraded from vista 32 to win7 32, encore works on my system for standard dvd's. I understand there is some issue with blu-ray that I believe, but am not certain, is the win7 problem. /Battle Vaughan
Old November 11th, 2009, 04:08 AM   #4
With Encore CS4 if I open Encore with my BR Burner enabled it will freeze my system - No Ctrl Alt Delete. Total crash, so I have to disable it via device manager and output to a ISO which I prefer anyways.
David Dwyer is offline   Reply With Quote
Old November 11th, 2009, 04:48 PM   #5
Thanks Battle. That's useful.
Can you confirm you are using Encore CS3 as opposed to CS4?
Old November 11th, 2009, 07:08 PM   #6
Initial information I got was that Win7 has some problems with BR encoding/burning that Microsoft is aware of and working on. In the meantime Adobe has a patch, that you may get through TS.
Old November 11th, 2009, 07:30 PM   #7
I have a pioneer BDR-203 and Encore CS3 installed in my system and Blu ray burning works fine. I think the best thing is to install windows from scratch. Re-format your hard drive and fresh install windows 7 as I did and Premiere CS3 and Encore CS3 works flawlessly even with blu ray burning.
Jun
Old November 29th, 2009, 01:57 AM   #8
I currently have Premiere and Encore CS3 working with Windows XP. I just started using the EX1 and started editing the HQ footage. No problems editing the footage and burning to SD DVD. However, I'm going to purchase the Pioneer BDR-205. Do I need to upgrade to Windows 7 and or CS4 to start burning Blu-Ray? Also how much RAM should I have? Any other info and system requirements to edit and burn Blu-Ray with a PC would be greatful!! Thanks
Al Kozak is offline   Reply With Quote
Old November 30th, 2009, 09:23 PM   #9
Are you refering to the Roxio pxhlp driver patch? I ran that but it did nothing.
I have to disable the Blu-Ray drive in device manager to get any sense out of Encore CS4 in Win7.
John Hewat
Mammoth Media Productions
John Hewat is offline   Reply With Quote
Old January 19th, 2010, 11:53 PM   #10
I have the same problem with Encore CS4 in Windows 7 Ultimate. I am going to try disable to BD drive to see if it works.
LA Color Pros Blog
Old February 4th, 2010, 01:59 PM   #11
I had a lot of issues with CS and Win 7 when working with Blu-Ray and the following blog post resolved it. I applied the patch (talked about a few posts up) and that took care of things. Here is the link: DAV's TechTable: CS4 and Windows 7
Simple Thought Productions - Life @ 30,000 Words per second
Josh Chesarek is offline   Reply
