FCS2 Reverse Telecine problem with HG10
I have been using the three fingered salute version of getting files from my HG10 into FCS2. It's worked well with smaller files ( a few GB), but I just tried the technique with two very large video files. They're approximately 1 hour each, and are sitting at around 50GB in size each. When I try the reverse telecine approach, Compressor seems to just flat-out die out from under me on both files. No error messages. I looked in Console, but nothing there either.
There was a discussion on Apple's boards about this problem prior to the 6.0.1 update, but nothing since. Again, this works fine for me as little files. |
It seems to be an FCS bug... in which case you can only file a bug report with Apple...
Alternatively, you might want to look for .m2ts/mts splitters that make sure that cadence is not lost when splitting. |
i've RT'd huge files (half hour to an hour) and not had any issues...
when you say flat out die what do you mean? i do think the current build of compressor is a time bomb though. not just for RT'ing but for anything. also do you have any aja stuff installed? i was having issues with aja qt components disrupting the RT process. |
