Capture problem XH-G1 to Avid Xpress Pro
I have a Canon XH-G1 and Avid Xpress Pro for the editing software. Avid's website says that they have tested the XL-H1 and it is "qualified" and that the XH-G1 "should" work similarly. My problem is that I have a good camera and good software, but can't use them because Avid Xpress pro won't capture from the XH-G1. Will a Sony HVR-1500 be necessary as a bridge? OR is there a less expensive, easier, way out there?
Unless... Perhaps you've recorded video in either 24F or 30F Frame mode and perhaps Xpress Pro doesn't support Frame mode video yet? I'm not sure what Avid's status is with Canon Frame mode video, anybody here know for sure? If it was Frame mode video, a Sony deck won't help you with that. |
http://www.avid.com/community/indie/Canon_FactSheet.pdf
Here's a pdf on working with the Canon series cameras. Since you're using Xpress Pro (Need Adrenaline and Media Composer) you can't use the HD SDI out on the G1. Like Chris said, give us some more info and we will bird dog it for you... ps. According to the pdf I guess Avid now sort of works with 30f if you edit into a 1080/60i timeline. |
Avid currently doesn't support 24f (yet?)...It will capture it (in my experience w/ my H1, but it'll look very jumpy). Try shooting in 60i and it should work fine (via firewire). Make sure your avid project preferences are correct.
Most people seem to be using a canon HV10, HV20, HV30 as feeder decks, cheaper than the sony decks and it'll play all the frame-rates. There's no avid deck templates for them, but I've heard they work fine. |
Thank you very much for your reply! I am shooting in 60i. For some reason no matter what I do Avid capture keeps telling me that there is no signal present. I am using Avid version 5.7.2 and when I got a hold of Avid they said that it does not support the XHG1. I also have an older version (5.4.???) on another computer that works perfectly fine with the XHG1. I don't know if I somehow tricked my other Avid into communicating with the camera or if it is just that the older version will work and the newer (updated) one will not. I appreciate any advise.
This really should be a solvable problem, even if it means upgrading to 5.8 (which I doubt).
What deck configuration are you using? Are sure you're on OHCI (simple but hey you never know). Do other cameras connect okay? Have you tried powering on the camera before/after starting Avid? I capture 60i out of an HV-20 all the time. There are no issues now (but I do remember getting a no signal present message when first setting it up). The G1 should be no different. The G1 is an amazing camera, BTW! |
