Multiple Processor Rendering
Does anyone know how the different versions of Avid handle rendering across multiple processors? Curious if it is better to have a slower Quad Core, or a faster Dual core when it comes to rendering. I've tried to look for an answer all over the place but can't seem to get a real answer.
Any insight would be appropriated. Thanks! |
I would definitely recommend a quad core for Media Composer 3.0 and above.
It really depends on which codec you're exporting to. Some codecs are multi-threaded, others are not.
As far as I know, Media Composer on a 32 bit platform is not multi-threaded. In other words, internal processing would not be much different on windows XP pro whether quad core or not. I understand that there are some processes that are multi-threaded, such as the 10-bit color correction module, but, that's about it.
According to Avid rep's, they will be going to multi-threaded processing when they go fully to 64-bit engines. |
Bill is right in that some functions can be written as multi threaded, while others are not. For instance, Quick Time itself is single threaded. I understood that the MC 3.x series had greater multithread functionality, so I typically watch the MS performance monitor for anything that takes any noticeable time. I can report that transcoding HDV to DNxHD145 uses all eight of my cores to about 80% each, drastically reducing workflow time. Other aspects of avid that are instantaneous may be single threaded or multithreaded, but I don’t care if I don’t have to wait.
Unfortunately for me, Sorenson 5.04 seems to be single threaded when producing mpeg-2 output from QT reference files of the DNxHD145 media. I recommend Intel Core 7 quad processors (920 is a bargain) for any new computer. This CPU will overclock itself if it finds some of the cores are unused. |
